Problem with MCL2A
This post has 8 Replies | 0 Followers
Zazouzt
Near Strasbourg France
Posts 222
Zazouzt Posted: Tue, Jun 9 2020 9:26 AM
Hi All,
I have several MCL2A in my house, and all work fine, except one.
I have no sound on the left side.  What can i do ?  it has the Number 2045.
 if some can help ...
Best Regards from rainy Alsace
Theo
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, Jun 9 2020 9:37 AM
Check all the connections.
Start with the speaker cable on the LHS, at MCL2A and speaker end.
Swap the speakers and/or speaker-cables over (L to R and vice versa) to 'fault find'.
Finally check the connections at both ends of the thicker MCL cable that connects the MCL2A to the rest of your system.  You will have to open up the MCL2A to check the terminals inside.
EDIT: See the photo - check that the wires from the thicker cable on the left are all correctly terminated:
solderon29
U.K.West Midlands
Posts 764
These are usually very reliable.
Check all connections to 'speakers and box as Guy has suggested
If you are convinced that the problem is inside the relay box,you can remove the pcb to investigate if the actual print has fractured under the MCL cable connector strip.
This can happen if the terminal screws were overtightened during install.
Nick
Zazouzt
Posts 222
Zazouzt replied on Wed, Jun 10 2020 2:48 PM
Thanks for your answer.
I'll check all cables etc..., and let you know in a few days.
Best Regards
Theo
Beofile7
Posts 150
Beofile7 replied on Wed, Jun 10 2020 3:55 PM
If your MCL2A has failed I have a new one somewhere?
Zazouzt
Posts 222
Zazouzt replied on Fri, Jun 12 2020 4:02 PM
i'm eventually interested.  How much do you ask for ?
Theo
Zazouzt
Posts 222
Zazouzt replied on Fri, Jun 12 2020 4:08 PM
I checked and re checked, but nothing ....
even my first mcl2a doesn't answer anymore.
Question :  when i put the beomaster 5500 to the mains, isn't a little click ?
i have only the red dot blinking twice.
Theo
Beofile7
Posts 150
Beofile7 replied on Sat, Jun 13 2020 5:11 PM
20 Euros + shipping from sweden.
Zazouzt
Posts 222
Zazouzt replied on Sat, Jun 13 2020 5:33 PM
That sounds good !
can we talk by mail ?
mine is   theoz (at)  free.fr
Page 1 of 1 (9 items) | RSS
