BeoSound 5 / Beomaster 5 & Beolab 5 - No sound
SVAUTO
Posts 2
SVAUTO Posted: Wed, Jun 10 2020 3:13 AM
I have a pair of Beolab 5 speakers we just picked up from an authorized B&O service center, I saw them operate there.
I connected the speakers to my Beomaster 5 / Beosound 5 system via power link cables.
The Beomaster 5 contains music in the music library.  I have selected Beolab 5 speakers from the settings menu.
I can't get any sound from the speakers.  The Beosound 5 unit appears to be playing the selected song, just nothing out of the speakers.
I do not have a remote for the Beosound / Beomaster unit.
Can anyone help what might be wrong with this ?
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Jun 10 2020 7:46 AM
1. Does the speakers turn on ?
2. When using the volumen wheel on the Beousond 5, is the blue volume indicator moving ?
3. Are you using the correct powerlink cables ?
/Weebyx
SVAUTO
Posts 2
SVAUTO replied on Wed, Jun 10 2020 2:45 PM
Hi
1) Both speakers calibrate normally.  After calibration, one speaker remains with the red 'standby' light on. The other speaker 'standby' light turns off after a few minutes. This speaker has a brand new amplifier in it, with the latest firmware, it was just redone.   In short, I think the speakers are ok.  I picked them up from the B&O service yesterday, where both speakers were demonstrated to be working fine.
2) The Beosound 5 blue volume indicator moves when i turn the volume wheel.
3) The powerlink cables are fully wired, they were advertised to be the correct ones for Beosound 5 etc. These are the thick cables.
Thank you for all of your help....!
lechatsurletoit
Posts 45
I would try putting in the settings your beomaster 5 in AudioMaster 2 mode or try other AM modes, especially if it's connected to a masterlink setup with an other master.
CB
> You are Here <
Posts 1,762
CB replied on Sun, Jun 14 2020 6:23 AM
SVAUTO:
Hi
Do you remember how ?
Did they use a non B&O amplifier or something like that ?
I’m asking because the BL5s may be in the wrong mode for your setting. You’ll need a Beo4 to change it...
stefan
200 miles from Struer
Posts 2,920
stefan replied on Sun, Jun 14 2020 11:01 AM
Don’t the BL5s turn on at all?
make sure, that BS5 is set to audiomaster (AM), BL5s set to L-R input (not LINE), and BL5 option set to L.OPT 0.
yes, you will need a Beoremote like Beo4, BL1000, Beo5/6, BL5000/7000 in one way mode...
Stefan
Page 1 of 1 (6 items) | RSS
