Stage gets an award!
This post has 19 Replies | 0 Followers
Chris Townsend
Qatar
Posts 3,531
Chris Townsend Posted: Wed, Jun 10 2020 2:05 PM
A bit of good news amongst all the grimness.
https://www.t3.com/us/news/t3-awards-2020-bang-and-olufsens-beosound-stage-is-this-years-best-soundbar
Well done
moxxey
South West, UK
Posts 5,359
moxxey replied on Wed, Jun 10 2020 2:19 PM
Chris Townsend:
Just received mine this morning. Must admit, a little disappointed as a speaker. Seems very 'flat' (no pun intended) sounding to me. I guess I'm so used to the bright and wide-sounding Edge and BeoSound 2. You get so used to such a high standard, you drop down and immediately notice a big difference.
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Wed, Jun 10 2020 3:39 PM
Good news indeed!  Well done B&O. Thumbs Up
Sandyb
Posts 2,186
Sandyb replied on Wed, Jun 10 2020 3:53 PM
That doesnt entirely surprise me.
I'm pretty sure you'll be happy with it in the end partnered with a TV (not sure if you have it connected to one yet).
But in isolation, I wouldn't conflate its positive reviews as a sound bar with it being a similarly good standalone speaker.
When your GX arrives, I'd love to see a picture of your installation - presuming you are wall mounting the GX.
If my 12-65 dies, a GX would be my ideal replacement, as the Eclipse design is still a little off to me, and the Harmony is absurdly chunky for a wall mount,
Anyway, pretty sure you'll be happy enough with the GX Stage combination when all is said and done - cant remember what speakers you used with your 12-65 before though, so cant comment on how much your audio experience is changing.
moxxey:
Chris Townsend:
Jaffrey2230
Washington DC
Posts 520
I use mine as a speaker and it's OK as a speaker. But as a Soundbar connected to my Apple TV (I tested it but can't use it since I have my Sony OLED on a table and there is no clearance for a sounder) it sounds amazing. the 3D effects for movies is pretty incredible IMHO. I have neither of your speakers so can't compare but neither can handle the 5.1 and Atmos audio that the Stage does.
B&O in my life 😊:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
moxxey
South West, UK
Posts 5,359
moxxey replied on Wed, Jun 10 2020 6:30 PM
Sandyb:
It's finally coming Saturday! Not sure when it will go up though. Sky keep putting my Sky Q installation back. They were due 2 weeks ago, put it off to today, phoned this morning to say they would be here later that morning, then phoned 20 minutes later to day that it's raining, so they can't go on the roof, so need to put it off another week!
moxxey
South West, UK
Posts 5,359
moxxey replied on Wed, Jun 10 2020 9:35 PM
Jaffrey2230:
I use mine as a speaker and it's OK as a speaker. But as a Soundbar connected to my Apple TV (I tested it but can't use it since I have my Sony OLED on a table and there is no clearance for a sounder) it sounds amazing..
Interestingly, you can connect the Stage to the BV11 wirelessly and the audio quality is better from the Stage than the 11-40. No delay, either.
Definitely sounds better as a TV speaker.
Jaffrey2230
Washington DC
Posts 520
The bass and 3D sound effects for movies are great on the Stage - it is surprisingly good bass for such a thin speaker. The Stage paired with an LG GX looks very similar to the LG W wallpaper TV, except the Stage sounds better and looks much better as well. The difference in sound from the Stage as a stereo speaker vs TV speaker might be the DSP tuning. It sounds amazing for movies with an Atmos audio track. You won’t be disappointed.
B&O in my life 😊:
Geoff Martin
Struer, Denmark
Posts 672
moxxey:
Just checking: you've played with the various presets and their parameters, right? Sorry if this is an obvious question - but it might be the solution to your problem....
Cheers
-geoff
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Thu, Jun 11 2020 9:20 AM
moxxey:
I've seen the CX and GX in the flesh yesterday. I like the GX housing much more than the CX and previous versions . More sturdy and looks better, Imho. It explains why there they need a different (vesa) bracket to mount the panel to the Harmony's soundcentre.
But there is a small minor detail. The B&O software isn't available for the CX and GX yet at this moment in LG's app store. I'm also told that the delivery of the panels are delayed.
moxxey
South West, UK
Posts 5,359
moxxey replied on Thu, Jun 11 2020 10:23 AM
Geoff Martin:
For sure! I had a good play with the B&O app. It's a superb speaker, just the Edge and BS2 have a 'cleaner' and wider sound and I'm just used to this. A B&O dealer described the Edge as having an 'American sound' and I can see where they are coming from. High highs, low basses.
moxxey
South West, UK
Posts 5,359
moxxey replied on Thu, Jun 11 2020 10:25 AM
Beobuddy:
Yep. I had to cancel my GX order with my B&O dealer. It was already 2 weeks late and they emailed on Tuesday and said it's now not expected for another 9-10 days.
I ordered from John Lewis who still had some in stock and bought the Stage + Remote from the B&O dealer.
I guess as the GX doesn't have the app support, this means the BeoRemote won't control the TV?
Mikipidia
Posts 2,169
Mikipidia replied on Thu, Jun 11 2020 11:33 AM
Providing it works the same was as the harmony with the cx/gx panels, take a usb drive to your dealer and he’ll be able to upload firmware on it that’ll make it work with the lg remote and stage.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
moxxey
South West, UK
Posts 5,359
moxxey replied on Thu, Jun 11 2020 12:05 PM
Mikipidia:
The dealer isn't even open :)
Mikipidia
Posts 2,169
Mikipidia replied on Thu, Jun 11 2020 12:24 PM
Well, it’s all digital so maybe he can email it to you? Stick out tongue
I’ve been sent software like that before via email, it’s probably around 5mb, you’ll just need a usb drive.
Beobuddy
Posts 3,972
Beobuddy replied on Thu, Jun 11 2020 1:44 PM
moxxey:
At the dealer's the CX was already wall mounted above a Stage and a GX was standing next to a Harmony, waiting for the bracket.
It's just a matter of time that the B&O app will be in the LG appstore, I was told.
moxxey
South West, UK
Posts 5,359
moxxey replied on Thu, Jun 11 2020 3:11 PM
Beobuddy:
The app is already in the appstore: https://gb.lgappstv.com/main/tvapp/detail?appId=955120&catCode1=&moreYn=N&cateYn=N&orderType=0&headerName=&appRankCode=&sellrUsrNo=
I don't think this is the issue. I think the CX/GX need a firmware upgrade to work with the B&O app according to my dealer and that is 'coming soon' (approx mid-July).
Mikipidia
Posts 2,169
Mikipidia replied on Thu, Jun 11 2020 3:49 PM
Just email hour dealer, surely he can email the firmware with a manualSmile
Beobuddy
Posts 3,972
Beobuddy replied on Thu, Jun 11 2020 7:39 PM
moxxey:
Beobuddy:
If you search through the LG appstore on the CX, you won't find the B&O app. At the C9 no problem and that works. Odd.
I assume that it's then a general firmware for all LG panels?
moxxey
South West, UK
Posts 5,359
moxxey replied on Thu, Jun 11 2020 8:41 PM
Beobuddy:
Yep, that's what I meant above. The app is available, but the CX/GX require LG to update the firmware to support it, which is going to be around mid-July.
Page 1 of 1 (20 items) | RSS
