I am looking in to update my BeoLab 9 and have a hard time deciding on new B20 og used B5. B5 has fo me always been dream but too expensive. Now they are within reach used but for less price I can get brand new B20 with new technology...any thoughts?
antwilas:I am looking in to update my BeoLab 9 and have a hard time deciding on new B20 og used B5. B5 has fo me always been dream but too expensive. Now they are within reach used but for less price I can get brand new B20 with new technology...any thoughts?
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Short and precise
What about Eclipse vs Harmony 65 inch?
Harmony 65 for better panel, sound and closer to a B&O design IMHO. I would go with LG GX + Stage over an Eclipse...
B&O in my life 😊:
I need the Tv as a set with B9 and B17 speakers so stage not an option :-) but I guess it have to be Harmony then :-)
antwilas:I need the Tv as a set with B9 and B17 speakers so stage not an option :-) but I guess it have to be Harmony then :-)
Fansastic:I have 55” Eclipse and love it. Harmony is better on both sound and picture again. If you need the moveable stand you need Eclipse. I like the Eclipse design very much, to me it is more stylish than Harmony. The movement is nice and in off stand cool but when on it is a bit in your face and I do not like the little gap between screen and speakers. BV Eclipse 55 Brass - BL 18 Brass - BL 19 Brass - BL 3 White - BS Moment - BS 2 Brass - BV Horizon 48 - BS3000 - BS 3200 - BS Essence - BL 4000 - V1 40 Black - V1 40 White - BLC NL/ML - H6 - H4 - E8 Motion - A8 Earphone - Beolit 12 - Beolit 15 - Beoplay A1 Green - Beoplay A3 White
I would always go for 5's too, unless you're in the US/your dealer of tech is prohibitively far away. In that case I would have more ease of mind with the 20's. but that's the only reason, sound wise the 5's are superior by a fair margin.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
With your last statement...are B5's high cost for spareparts because they brake???
No but yes, so possibly. We're talking about older speakers and depending on the year you get and how they've been used it could be so. but mostly that you don't get warranty(depending) and if something happens they are bloody heavy, 61 kg/134 lbs each. 20's are very easy to move compared.
in other words, it depends, new vs new (or refurb) then lab 5's all day long. I don't consider any real repair cost prohibitive for 5's unless you payed top dollar for a set, because you get so much value for money. But IF!! IF you need to do it and your dealer is very far away, it's a pain in the ass to get them there.
Thanks a lot for your reply Mikipidia and a very valid point...the B5's I have found are from 2009 but do not know the background. I buy from a dealer and will get 12 months warranty but it may be a bit of lottery but price is 7400 dollars which I guess is pretty fair...
how would I know if it is mk1 or 2's ?
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
antwilas: how would I know if it is mk1 or 2's ?
Yeah how do I know if they are mk1 or mk2 ????
I’d go with a BL 20 because it has newer technology.
serial numbers mostly
I don't know of the top of my head, I usually ask my dealer friends to check it for me. Surely your dealer should know or a dealer on the forum here should be able to check them :)
The similar decision is whether given a choice you’d buy a new BMW 5 series (BL 20) or go with last generation 7 series (BL 5). To me, I’d go with the current gen because of the warranty, support and technology.
