LG GX + Stage is here, some initial feedback
This post has 76 Replies | 0 Followers
moxxey
South West, UK
Posts 5,359
moxxey Posted: Mon, Jun 15 2020 9:19 AM
Firstly, photo to follow. Not quite fully set it all up yet.
LG GX 55" + Stage + BeoRemote arrived Saturday. First impressions? Picture quality is simply stunning, especially for 4K-sourced movies and content. HD looks good, too.
Surprisingly the TV has a fairly decent speaker. Indeed, it's so decent sometimes I can't tell if the Stage is on or the TV speaker when watching something like the news and other regular TV.
Apps are good. So good I've realised I won't need the Apple TV. You get the Apple TV app, Netflix, Prime Video and other apps I use.
But, some less good news...
- Stage sometimes doesn't turn on with the TV. Anyone have any ideas on this? Very frustrating.
- BeoRemote, as expected, doesn't work with the TV yet. No access to the B&O app on the LG Appstore.
- No UK catch-up apps! No iPlayer, no All 4, ITV Hub, nothing. Incredible.
All in all though, thoroughly recommended.
Sandyb
Posts 2,186
Sandyb replied on Mon, Jun 15 2020 12:20 PM
I dont think any of the 2020 LG's have the Uk catch up streaming apps.
Its and LG thing (obvs) - something has happened between them and the Freeview alliance (or whatever it is called).
It will get sorted though - but may take a search of LG forums to get an idea of timeframe,
moxxey
South West, UK
Posts 5,359
moxxey replied on Mon, Jun 15 2020 3:04 PM
Sandyb:
I'm more worried/annoyed that the Stage doesn't turn on with the TV, to be fair.
Mikipidia
Posts 2,169
Mikipidia replied on Mon, Jun 15 2020 7:36 PM
I have one with a C9 panel and have no issues, also the C9 has those apps available. Don’t know why it’s any different for the CX
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
moxxey
South West, UK
Posts 5,359
moxxey replied on Mon, Jun 15 2020 8:31 PM
Mikipidia:
I think the GX hasn't had full B&O implementation so far. You can't access the B&O LG store app, the TV requires a firmware upgrade (due mid-July), so it's not quite fully integrated....yet. Same with the CX.
Still, the picture quality is unbelievably good. I used to bang on about my BV12-65, but this about 10 levels higher. So good. It's almost embarrassingly good in 4K.
Mikipidia
Posts 2,169
Mikipidia replied on Mon, Jun 15 2020 8:53 PM
With the latter parts with the apps I meant the freeview and itv/channel4 aps and the like too. They seem to all be working fine on the C9 panel, so maybe it’s the same for those too. As in not fully validated by lg for their content store just yet?
moxxey
South West, UK
Posts 5,359
moxxey replied on Mon, Jun 15 2020 9:11 PM
Mikipidia:
As Sandyb mentioned earlier, LG lost the agreement to supply those apps for 2020, so any new TV shipped this year won't now include those apps (at least until they sort out the agreement).
Won't be a big issue for me as my Sky Q box should be installed Friday.
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Jun 16 2020 7:34 AM
Nice!
Did the flat mounting wall bracket for the GX work well? Think that is a very clever solution.
Look forward to pictures.
MaxH
Posts 126
MaxH replied on Tue, Jun 16 2020 7:36 AM
The Apple TV plugged into an HDMI port will give you all the UK catch up apps.
Emil Jensen
Denmark
Posts 766
moxxey:
Yea I remember, Welcome to the world of OLED Big Smile
moxxey
South West, UK
Posts 5,359
moxxey replied on Tue, Jun 16 2020 11:03 AM
Emil Jensen:
moxxey:
The only downside - there has to be a downside - is that SD looks awful (as it's seriously upscaled to 4K), and low-quality HD looks a bit washed out compared to the BV12-65.
Obviously top quality HD or 4K is another level and then some.
Emil Jensen
Denmark
Posts 766
moxxey:
Emil Jensen:
moxxey:
Yes that is very true,
Lucky I only look at Streaming, so everything is good except HBO
And Itunes have very good deals on 4K HDR film, highly recommend
Jaffrey2230
Washington DC
Posts 520
I can't remember if LG allows for input specific settings. If it does, then you can use a more vivid default setting (so that SD looks brighter and more colorful) and use the Apple TV 4K input calibrated for HDR. In general, since HDR is much brighter and more colorful, SD content with a setting that is optimized for HDR tends to appear dimmer and washed out in my experience. You'll also find that you might prefer the video and audio from some of the Apple TV app over the default LG Apps only because the Apple TV Apps are implemented better in some cases than their WebOS versions (in my experience Disney+ and Netflix fall into that category). YouTube App on the LG might be better since in my case (I have a Sony OLED) the Android TV version of YouTube is slightly better than on the Apple TV, but Netflix on Apple TV is better, even with the default Android app having access to Sony's Netflix calibration.
So using the Apple TV you might be able to get the best of both worlds - SD and HD.
The Apple TV remote works perfectly with the LG GX TV and Stage using HDMI CEC (although the Beoremote One looks much nicer :))
B&O in my life 😊:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
Chris Townsend
Qatar
Posts 3,531
moxxey:
Let’s have some pictures already.
moxxey
South West, UK
Posts 5,359
moxxey replied on Tue, Jun 16 2020 8:52 PM
Chris Townsend:
moxxey:
It’s a black TV on a wall. Visualise it.
ToeKneeAus
Posts 54
ToeKneeAus replied on Tue, Jun 16 2020 10:34 PM
Its good to hear your thoughts on the GX , I've just got my CX (replacing a BV7-40 Mk3) and now its sitting proud on the BV7 floor stand thanks to STBrackets.
  • Yes - the speaker in the TV is quite good for its size - I do find changing the sound setting (from AI Pro or Cinema to Voices ) is needed soemtmes to make voice more distinct - otherwise they get a bit lost.
  • The picture quality is amazing - but i guess i was coming from a low bar with the BV7 :-). SD isn't too bad - but i'll always veer towards HD or better if possible
  • The apps on Web OS are pretty comprehensive here in Aus - but I cant find one for Channel 10's "10 Play" so i may end up keeping an Apple TV attached for that (just in case).
Still trying to decide about a Stage or standalone eclipse Sound Center - I guess i'll be waiting till the Stage works with the GX/CX before being able to try it out in home.
Chris Townsend
Qatar
Posts 3,531
moxxey:
I was thinking more about the stage placement.
moxxey
South West, UK
Posts 5,359
moxxey replied on Wed, Jun 17 2020 11:33 AM
Chris Townsend:
moxxey:
It's just face up on drawers! It's not on the wall. I'll try get a photo once it's all finished...
moxxey
South West, UK
Posts 5,359
moxxey replied on Wed, Jun 17 2020 11:35 AM
ToeKneeAus:
Interesting, thanks. I need to have a bit of a play with the picture calibration, too. At the moment I'm on Expert - Bright Room as my preferred setting.
vlohjr1
Posts 553
vlohjr1 replied on Wed, Jun 17 2020 12:58 PM
Chris Townsend:
Let’s have some pictures already. Beovision Eclipse, BeoLab 17,Beolit 15, Beoplay A2 Active
A TV on a wall! Great sound
AnalogPlanet
Vienna, Austria
Posts 678
jvezina
Montreal, Canada
Posts 200
jvezina replied on Wed, Jun 17 2020 3:02 PM
ToeKneeAus:
In the meantime, you can reuse the Beolab 7-2 speaker of the BV 7. Do a search in the forum for the various ways of connecting it. The best is to use an external DAC connected to the optical output of the TV.
Ammier
Posts 52
Ammier replied on Wed, Jun 24 2020 10:23 AM
Moxxey,
Thanks for this thread! Much appreciated. Just ordered a GX65 and stage for our small tv room. TV going on the wall and stage sitting on a cabinet.
Did you sort the issue of the stage turning on automatically with the TV or is that subject to an update in the future?
Regards,
Ammier
Ammier
Posts 52
Moxxey,
Regards,
Ammier
moxxey
South West, UK
Posts 5,359
moxxey replied on Wed, Jun 24 2020 11:06 AM
Ammier:
It's random! Mostly it works, but it's only off the Apple TV. It's almost as if the Apple TV doesn't sync properly with the TV.
My latest issue is that the external LG Blu-ray player keeps dominating connections, so the GX keeps switching to the Blu-ray player and starts playing a movie. I can even manually turn off the player and the TV starts it up again. Perplexing.
Mikipidia
Posts 2,169
Mikipidia replied on Wed, Jun 24 2020 11:46 AM
So maybe there is an issue in lg’s software where something in the priority stack goes wrong? Maybe that’s why the stage doesn’t always switch on either?
I can try and connect my aptv to the c9 &stage see if i get the same, but i doubt it somehow. Is there a way to let lg know?
Btw, is your aptv connected to the stage or to the lg?
Emil Jensen
Denmark
Posts 766
moxxey:
Ammier:
These problems were what I was dealing with before turning to a Beovision with PUC.
CEC have never worked well for me, sadly.
moxxey
South West, UK
Posts 5,359
moxxey replied on Wed, Jun 24 2020 9:33 PM
Emil Jensen:
True, but I find that the PUC doesn't always work smoothly either, especially with Sky. The number of times it's completely stopped working and I've had to spend a good few minutes playing with the cable to get it working again! Swings and roundabouts and I'm not forking out £8000+ for a 2017 Eclipse :)
I'd rather have a single unit like the Eclipse, but B&O just make it so hard. Perplexing why they don't update the panels as frequently as they did with, say the BV7.
I can buy a GX 55", GX 65", 2 x Stage and 2 x BeoRemote's for 1 Eclipse. And have change left.
kawo
Posts 148
kawo replied on Thu, Jun 25 2020 10:22 AM
same here CEC has its glitches, with Beoremote One and a Sony BluRay the skip buttons do not skip, they fast forward/backward. Useless, most need function for me für Music. Is there an other key which does it?
moxxey
South West, UK
Posts 5,359
moxxey replied on Thu, Jun 25 2020 10:53 PM
Update.
Sky Q finally installed today after 5 weeks waiting (every time the engineer was due it was raining and they won't go on the roof when it rains).
Picture quality on the GX is astonishing. Even regular HD looks like 4K due to the fantastic upscaling. Obviously 4K is another league. First time watching Sky Sports in 4K and it's stunning - looks like you're watching in the stadium
But, along with the positive, there's a negative. You can't control the Sky Q box from the LG remote. Or can you? Anyone managed this?
Bv7Mk3
uk
Posts 781
Bv7Mk3 replied on Fri, Jun 26 2020 8:35 PM
In answer to the no app thing? It will some time in
2021time frame to add them.
All new 2020 lg tv's will have no apps installed.
PaulGiles
Posts 218
PaulGiles replied on Fri, Jun 26 2020 10:11 PM
To be fair, as much as I tried to persuade the family of the Beoremotes merits of one piece aluminium design etc they put it in the drawer and talk to the Sky Q remote.
It works very well.
The BV11 and BR1 have been retired in favour of the LG and stage with SkyQ remote.
moxxey
South West, UK
Posts 5,359
moxxey replied on Sat, Jun 27 2020 8:02 AM
PaulGiles:
It works very well.
Paul, this makes no sense? I think you're saying that the BeoRemote doesn't work with the Q?
Another update from me. Sky Q installed Thursday. Watched football in 4K for the first time ever last night. Seriously? OMG. It's so good on the GX it looks like you're there - never seen anything like it.
My GX 65" arrives this week. Can't wait. I loved the BV12-65 picture quality, but it's no way near the level of a GX and 4K. I don't get astonished often, but this is something else.
And, yes, slightly annoying nothing controls the Q box. Even the LG 'magic remote' (which claims it does).
PaulGiles
Posts 218
PaulGiles replied on Sat, Jun 27 2020 8:15 AM
I will do more testing of it over the weekend as I have only recently had Q installed too.
moxxey
South West, UK
Posts 5,359
moxxey replied on Sat, Jun 27 2020 11:06 AM
PaulGiles:
Thanks. The BeoRemote can't control the GX yet, but this should be fixed sometime in July. Would be ace if it can control the Q box, too (not holding out too much hope though).
jvezina
Montreal, Canada
Posts 200
jvezina replied on Sat, Jun 27 2020 10:00 PM
moxxey:
PaulGiles:
Is there preliminary software that can be obtained from the dealer ? That was the case for the C9 last year before the official release by LG.
butch1
Posts 384
butch1 replied on Sun, Jun 28 2020 2:17 PM
I think that is poor on LG side, I am glad I got C9 app works perfect, beoremote perfect, and all the tv apps👌 This should have all been put in place before launch. I have never had any issues with stage, C9 65 and Beoremote, and Apple TV 4K works well on CEC too👌
I don’t see much difference in c10 too be fair or less your a gamer, I use it for movies only in bedroom, and streaming apps, so having them all working and present is a must.
butch1
Posts 384
trackbeo
Posts 644
trackbeo replied on Wed, Jul 22 2020 9:31 PM
Took 'em a while, but finally LG is selling their GX-matching soundbar.  You might argue about its "design language" (kangaroo pouch) versus the Stage, but I like it: identical width, matching edge profile & vertical close-mount giving an integrated look.  65" only, wallmount only (but that's the point of a GX).  Comes with a separate "wireless" "sub"woofer -- required, obviously, with that slim a box.  Haven't heard it myself since it's brand-new, but presumably it has a less-spacious sound than the Stage because it's a basic L/C/R speaker and the crossover to the woofer is going to be pretty high.  But to make up for that, it supports a true rear speaker pair; not clear if the wireless is built-in like the woofer or requiring their transmitter box.  From: https://www.lg.com/us/home-audio/lg-gx-sound-bar :
poodleboy
Posts 303
poodleboy replied on Wed, Jul 22 2020 10:12 PM
trackbeo:
This should go well.
1. It is Meridian tech branding.
2. It is 1/2 the price
3. It has a separate sub (yuck) and WISA/Bluetooth for rear speakers?
3. It doesn't work with the BeoRemote.
Weird that LG markets 2 "luxury" brands for their TV audio, plus their own. A bit like Andrew Undershaft.
Wonder if B&O has flexed its muscle over this?
Page 1 of 2 (77 items) 1 2 Next > | RSS
DigiCert Secured Site Seal
