I'm using 2 M3's as stereo computer speakers. They are connected through the LINE IN connector and a splitter cable which takes a stereo 3.5mm jack and turns it into two mono 3.5mm jack plugs.
Apart from that, they can also still be included in airplay or other multiroom setups. So if I need them to play my living room music in sync, I just include them in the airplay stream.
Beolit 12 - Beolab 4 pc (dead now) - Beoplay H5 - Beolab 9 - BeoRemote One BT - Beoplay M3
Hi, das sollte über Google / Chromecast funktionieren.
