BeoLab 3 only sound from the silver hood on top.... Also re-painting shell...
Nigel Fernandes
Sydney Australia
Posts 4
Nigel Fernandes Posted: Thu, Jun 25 2020 6:58 AM
Hi, hoping someone might know how to or where to fix in Sydney Australia a Beolab 3, 1 speaker only plays sound from the siler hood on top, the side speakers emit nothing. I also have the casing a bit scratched, wondering if anyone in Sydney has a suggestion as to where to have them re-sprayed.
kawo
Posts 148
kawo replied on Thu, Jun 25 2020 10:16 AM
Had the same issue with no lows, the bass amplifier was broken. I was able to source one from eBay, with the service manuel it was an easy plug and play job to fix. Maybe you can find a broken BL3 with the most common failure of the power supply (does not switch on at all) and you can just take the amplifier from it. The previous owner of my spare part did exactly that.
hope that helps
BenSA
Durban, South Africa
Posts 1,404
Repainting Beolab 3's are easy to do although you have to take them apart and you should use a anti-static bracelet.
I removed the original paint using paint remover, washed them and then after the dried I sprayed with an kitchen appliance spray in a can. Gave a beautiful smooth and flawless finish.
Nigel Fernandes
Sydney Australia
Posts 4
Wow, looks great, do you have a link to how to dissasemble the units by any chance?
Nigel Fernandes
Sydney Australia
Posts 4
Thank you, I'll keep an eye out on EBAY.
kawo
Posts 148
kawo replied on Fri, Jun 26 2020 4:49 AM
You can download the service manual here from beoworld if you are a premium member.
Page 1 of 1 (6 items) | RSS
