Hi All -
I am just getting my BLGW working with my ML components. I have my Philips Hue bridge connected and can manually control lights.
I would to create a macro to do this simple thing:
Press DVD on my Beo4 sending to the BS3 IR puck
Have a Hue scene get selected (eg movie).
Is this possible?
I can see the Hue scene, but the DVD button is nowhere in the Command pull down. Do I need the BLGW to recognize that the BS3 has changed states to playing a DVD, and then do something after that?
Thanks,
Gregg
Eclipse 65V1-32Beosound M5Essence MK2BLI
Thanks Seanie. After I posted I tried the capture feature from pressing DVD on the Beo 4, and it captured the complete sequence including source activation. I assigned it to a Hue scene, and presto it just worked. Pretty amazing really. It works every time now.
-Gregg
