BLGW Newbie looking for Macro help with BL
Gregg
Colorado USA
Posts 143
Gregg Posted: Sun, Jun 28 2020 1:59 AM
Hi All -
I am just getting my BLGW working with my ML components. I have my Philips Hue bridge connected and can manually control lights.
I would to create a macro to do this simple thing:
Press DVD on my Beo4 sending to the BS3 IR puck
Have a Hue scene get selected (eg movie).
Is this possible?
I can see the Hue scene, but the DVD button is nowhere in the Command pull down. Do I need the BLGW to recognize that the BS3 has changed states to playing a DVD, and then do something after that?
Thanks,
Gregg
Seanie_230
UK
Posts 2,278
Hello there
It’s been a while but can you not put the BLGW into capture mode and press the DVD button you want and see if its captured.
If not you might need to use light commands as these are passed back to BLGW if you selected it in the menus.
I am not sure source changes are immediately captured.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Gregg
Colorado USA
Posts 143
Gregg replied on Tue, Jul 21 2020 5:19 PM
Thanks Seanie. After I posted I tried the capture feature from pressing DVD on the Beo 4, and it captured the complete sequence including source activation. I assigned it to a Hue scene, and presto it just worked. Pretty amazing really. It works every time now.
-Gregg
Seanie_230
UK
Posts 2,278
Sounds good to me :)
I need to order some bits to add to my system at home
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Page 1 of 1 (4 items) | RSS
