Hi, I have a beovision 11 which I have beolab 18's as front speakers. I have a pair of beolab 3 speakers I want to add as rear speakers. I have power link to rj45 converter. can I daisy chain the right rear off the right front beolab 18 or do I have to get the cable back to the connection to the TV? I want to do the same with the left as I do not have much space in the buried trunking for my cables. Many thanks ed
Hi and welcome to Beoworld.
Assuming you want to use the BL3’s as rears (or probaly more correct as surround) speakers, you must tell the tv, the surround processor, that the must receive that sound signal. Therefore they need a seperate connection.
Daisychaining them the way you suggest, wiil just make them another pair of front speakers.
But you can daisychain the fronts L <-> R - and you can daisychain the surrounds L <-> R.
Excellent thanks. Much appreciated. I'll run the cables and connect direct to the TV. Just to be clear am I correct in thinking I should select them as surround not rear.
thanks
ed
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
In general you call the speakers in a 5.1 setup = front left - center - front right - surround left - surround right (and the sub).
If you have a 7.1 setup the additional speakers are called rears and are placed behind you, and not like with the surrounds approx at the sides of where you sit.
Please notice, that these things often are mixed up!
If you have a 5.1 setup, you have surrounds.
Which tv do you use?
Thank you both so much for your quick responses. Its a great help. am going to try and run the cables tomorrow. I have a beovision 11.
Millemissen:Hi and welcome to Beoworld. Assuming you want to use the BL3’s as rears (or probaly more correct as surround) speakers, you must tell the tv, the surround processor, that the must receive that sound signal. Therefore they need a seperate connection. Daisychaining them the way you suggest, wiil just make them another pair of front speakers. But you can daisychain the fronts L R - and you can daisychain the surrounds L R. MM There is a tv - and there is a BV.
