Beosound Moment
This post has 19 Replies | 1 Follower
srs65
Posts 9
srs65 Posted: Mon, Jul 6 2020 11:38 PM
Are there any other compatible media servers other than Twonky? Thanks!
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Tue, Jul 7 2020 7:25 AM
srs65:
What I know :
Minimserver is very good and fast, while requiring more technical skills to get the most of it. Caveat: it is not a photo media server which prevents using it also for artist’s image self management that would be leveraged by the Moment when in Expert mode considering that Gracenote is no longer used by B&O to fetch artist images. Not an issue if you are not in Expert mode where unavailable artist’image is replace by an album cover.
Various NAS media server (Synology, QNAP, WD) seem to work according to some forum users.
PLEX does not work.
There are surely other depending on the platform you are using (Windows, OSX, Unix/Linux, NASes, etc...)
srs65
Posts 9
srs65 replied on Mon, Jul 13 2020 7:51 PM
Thanks. I have an iMac. So I need something compatible with that. The problem with Twonky is they went bankrupt and there are no software updates. I’m having problems with my iTunes playlists
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Mon, Jul 13 2020 8:57 PM
Minimserver works on OSX
I think Minimserver manages m3u playlists, so would require iTunes playlist export, not as integrated as Twonky was ... when working
I don't know if the Moment would see playlists exposed by Minimserver, never tested, but I see no reason why not.
srs65
Posts 9
srs65 replied on Mon, Jul 13 2020 9:30 PM
Thanks. Minimserver requires Java. I can't download Java.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Jul 14 2020 10:36 AM
srs65:
Quite extraordinary! You would be the 1st (?)
Why so?
srs65
Posts 9
srs65 replied on Tue, Jul 14 2020 11:00 AM
Apple says it’s not trusted & high risk for virus & will not let me download. I downloaded FireStream yesterday and it is working perfectly. All my music shows/plays that are in my iTunes playlists. Thanks for all your help.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Jul 14 2020 3:25 PM
srs65:
You can download it without problems! Just did it. But when installing you get a typical Apple message.
What Apple does: "It's not an Apple app-store item", so it says it can't be trusted. But can't it be trusted????
To install it anyway, right click the Java 8 update 251 icon and choose "Open". If you find it trustworthy you can open and install Java.
NB: do you know how many devices running Java? Do a search..........
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Wed, Sep 2 2020 2:46 PM
Today I found that when I listen to any Deezer album, the Moment systematically adds « Solitude » track by Duke Ellington at the end of the album tracks ....
I opened a case with B&O, waiting for an answer
..... I feel alone!
Steph
France
Posts 1,059
Steph replied on Wed, Sep 2 2020 6:51 PM
Is it a good idea to buy a second hand Moment for this:
- Listen to the radio
- Listen to music stored in a Beomaster 5
i don’t have deezer or spotify. The Moment could replace a Beosound 5
seethroughyou
UK
Posts 999
I can’t but help feel very disappointed with the Moment and B&O and would now be very reluctant and wary to ever spend money on a similar product. Pattern play still not working and the general use and stability between the tablet and dock is atrocious.
I recall the dealers gently guiding me to other products but what they were actually doing was steering me well away from the Moment when I enquired about it. I should have read between the lines and picked up on this cue but like some crazy B&O nutter I was blinkered to their subtle steering. What a waste of money and all the hours trying to get it to work properly. It’s left such a bitter taste that sometimes I just want to throw it away and forget about it. It’s presence now serves as an alarm in the morning to play radio. A glorified alarm clock (when it works).
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Steph
France
Posts 1,059
Steph replied on Wed, Sep 2 2020 6:55 PM
Wow! So, not a very good idea 😒
jowus
Posts 161
jowus replied on Thu, Sep 3 2020 10:33 AM
seethroughyou:
I concord with you! I just wrote about this in Steve’s Post. I can’t understand why they didn’t get Software Gurus to help them to get it running! Big Waste of Money! The same as Beo6 Remote, they just left behind to sit for nothing! And that was about $600! The Qualitative is gone out of their Menu!
HH1971
Posts 58
HH1971 replied on Sun, Sep 6 2020 8:18 PM
I totally understand you. I deeply regret my Beosound Moment (and my Beosound 35) purchase til today, too.
Tassos
Athens
Posts 323
Tassos replied on Mon, Sep 7 2020 7:15 AM
HH1971:
I totally understand you. I deeply regret my Beosound Moment purchase til today, too.
Couldn't agree more!!!!
donderbeestje
Posts 29
I agree completely. My beosound moment has worked only 9 months without any problem since i bought it in 2016. Only after a complete new software update after complaining more than 2 years and a lot of frustration It worked for 9 months. Now since april this year the tablet doesnt work anymore and i use only my ipads and mobiles to listen to the music. The dealer changed the battery but the tablet keeps flashing and is not useable. If it werent for the beautifull beolabs 18 and 19 which i still find the most elegant speakers in the world i would sell everything and take a 4 times cheaper sonos system. What a waste of money. b&o is nothing more than status and moving gadgets without really adding any new things on the market. They should get a penalty for bringing products n the market which are not useable. Bye bye 2195 euro plus frustration for 3 years. AngryAngry
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Sep 7 2020 8:46 AM
If my Moment tablet shows this phenomenon (once or twice a year), I let the battery drain completely, put it back on the Moment and do a reset of the tablet.
Until now it ALWAYS came back to life.
And though I disliked the use and sw at the start, I now use the Moment on a daily base much to my satisfaction.
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Sep 7 2020 11:14 AM
I bought the Moment immediately after launch.
I even visited the Moment press launch at CES in Las Vegas Smile
Agree with all posters that Moment was not a good product until the firmware was re-done. After that I really enjoyed Moment and it very much fulfilled the purpose that I had when I initially purchased Moment.
When it was discontinued I got some assurances from people inside B&O that bugfixing and fixes for providing the services running would be provided. That obviously is no longer the case.
I sold my Moment April last year.
I think B&O miss-judged the market demand for such a product. High price, low demand, and crappy software must have created a challenge for the dealers.
The Moment is prob the biggest disappointment from B&O ever. I tried to talk myself into buying one but it made no sense for the costs alone. when I heard what a software disaster it really was I'm glad I never got it.
I did make a much better alternative though for 1/5 the cost.
Get this Yamaha wxc-50. You can connect almost any B&O speaker to it on the pre-out:
https://usa.yamaha.com/products/audio_visual/wireless_streaming_amplifiers/wxc-50/index.html
Then use your iPhone or even buy the best iPad money can buy to replicate the Moment. Except you get a system that is much much cheaper and works 10000x better in every way.
There is also software for Mac to control the Yamaha.
Other than it doesn't have wood on one side ;)
BeoLab 18's. Beolab 3's. A8. A9. A2. H7.
Steph
France
Posts 1,059
Steph replied on Mon, Sep 7 2020 6:03 PM
Thanks to all for your answers. Moment is definatly not a good idea.
I will keep the BeoSound 5. Very sad that B&O doesn’t have a true audio system anymore.
I know the market wants headphones and wireless speakers but for me, nothing can beat a real stereo hi-fi system 😊
Page 1 of 1 (20 items) | RSS
