Hello,
Is there anything known about wether there will be a new BeoSound Stage with PUC support in the near future or not? For me the Stage is a great product but as it lacks PUC it really makes it more cumbersome to use as a replacement. I want to replace my lovely BeoPlay V1-40 (anyone need one?) as I don't think my wall can carry the weight of it. I have the floor, table and the roof mount too but I feel that it takes too much space in the small space I use it.
If I do that, then I need the following:
• Good speaker (Hence the stage)
• Nice TV with less weight
• PUC integration for Apple TV and IPTV box.
For me it is so weird they let it out without PUC as it is such a small extra feature that makes a ton of difference. It is available in the BeoSound part of the eclipse and harmony so it shouldnt be that hard to incorporate in a product as the Stage.
Maybe I should wait with replacing my TV or just get something else and live with ugly remotes instead of using a single BeoRemote One (I really do not want that...).
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
I would just wait, you love your V1, it looks great in white, it has PUC (you like that too), and the BROne (you like that too).
I'm sure the wall can take it.
If you replace it you will mount a replacement TV on the wall and also the Stage on the wall.
Out of interest i did see the LG GX (the gallery version 10) unboxing and that sits very flush with the wall and has an interesting bracket, but that's only in larger sizes.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Mikipidia:The apple tv works perfectly for me over cec, so no need for puc imho. Which iptv service do you have? Most will have an app and mine works just fine on the lg c9. So imho puc isn’t all that needed really unless you have a settop box that’s mandated by a provider with out cec. New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0 Mikipedia on YouTube (finally ) https://www.youtube.com/c/Mikipedia Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Aussie Michael:I would just wait, you love your V1, it looks great in white, it has PUC (you like that too), and the BROne (you like that too). I'm sure the wall can take it. If you replace it you will mount a replacement TV on the wall and also the Stage on the wall. Out of interest i did see the LG GX (the gallery version 10) unboxing and that sits very flush with the wall and has an interesting bracket, but that's only in larger sizes.
In case you really want to get rid of the V1 (why shouldn’t your wall could handle that)........go for an LG GX, when that will be available with the Stage.
Just run everything off the ATV4K connected to the LG and controlled via CEC.
You probably won’t need that Arris box, if there is a native tvOS app for your tv service.
One reason for keeping the V1 however, would be the ability to have a proper 5.1 setup.
Millemissen:In case you really want to get rid of the V1 (why shouldn’t your wall could handle that)........go for an LG GX, when that will be available with the Stage. Just run everything off the ATV4K connected to the LG and controlled via CEC. You probably won’t need that Arris box, if there is a native tvOS app for your tv service. One reason for keeping the V1 however, would be the ability to have a proper 5.1 setup. MM There is a tv - and there is a BV.
...and I can confirm that even LG OLED C9 has the Apple TV app and it works nicely. On top, I do have the Apple TV box connected as well to one of TV's HDMI ports and I'm controlling it via BR1.
Very cool. :)
AnalogPlanet:...and I can confirm that even LG OLED C9 has the Apple TV app and it works nicely. On top, I do have the Apple TV box connected as well to one of TV's HDMI ports and I'm controlling it via BR1. Very cool. :)
I have only one ATV. I use it to run some streaming apps like Eurosport Player, ATP Tennis TV etc.
The other thing on LG TV is the Apple TV App which is essentially Apple TV+, some streaming services and some content providers.
Aussie Michael:Also the CX/GX has the built in Apple TV (app) so you wouldn’t need a separate Apple TV box. That is one of the main differences between the 9th gen from what i was reading. I will have to look again to see the difference between the interfaces Mike (square).
