Beolab 5 set up with Beovision 11
This post has 10 Replies | 1 Follower
alvinedyvane
Portsmouth
Posts 17
alvinedyvane Posted: Wed, Jul 8 2020 3:24 PM
Hey all.
I want to maximise the sound and film experience with my Beolab 5's and was wondering if any of you have a guide on how to best set them up.
I have obviously had a good play around but it is not clear on how to get the best bass out of them. I also have two 8000's for rear.
I also wanting to connect my Beolab 2 (I know what you are going to say) but once you connect the 5's the system somehow does not allow this. Is there a bypass or trick or am I doing something wrong?
Thanks all
Alvin
lawrencejmcook
Posts 742
alvinedyvane:
Hey all.
Thanks all
Alvin
Hi Alvin,
I think that Geoff Martin has expounded on this elsewhere, but the short story is that the 15-inch subwoofer in each BL5, driven by a 1kW amp is more capable then the single 10-inch subwoofer (with two drones) driven by a 750W amp in the BL2.
With bass management set to on, your BV11 will divert bass from the BL2 to the BL5s.
You can, if you wish, switch bass management off, and have bass boing through all three speakers. It’s up to you determine which sound you prefer.
Although my TV’s sound processing is more primitive than yours (BV9, BS3) it did the same. In the end I just disconnected the BL2 as it was superfluous (as Lee of Lifestyle AV warned me it would be Big Smile).
Lawrence
alvinedyvane
Portsmouth
Posts 17
Great stuff Lawrence. I will try this as I did get the Sub working on the previous Beovison 5, it sounded great.
The speakers are self amped though right, so I wonder what the TV takes away or adds?
Is there anywhere on here that shows how best to set up the Beolab 5's with a Beovision 11? Would be good to make sure I have them set up right.
lawrencejmcook
Posts 742
alvinedyvane:
Yes, BeoLab 5s and BeoLab 2 have their own in-built amplifiers. The TV has been programmed at the factory to know that the BL5s produce better bass than the BL2, and so if Bass Management is set to ON in the BV11’s sound settings, it will not send any signal to the BL2.
Honestly, you may as well use it in another setup. I see you have a number of threads on the go here, so perhaps you can find another use for it.
In terms of BL5 setup, there are a number of forum threads that offer advice. I would say:
- Place them where you want in the room. They weigh more than 60kg so you don’t really want to move them around unless you’re really unhappy.
- Connect them to the BV11 with fully-wired Powerlink cables (RJ45 to 8-pin DIN). Steve at Sounds Heavenly could help you with these.
- Tell the BV that the BL5s are connected and define their role, distance from your listening position, etc.
- Calibrate the speakers.
- Pour yourself something cold to celebrate and just enjoy a good movie or album.
Lawrence
Lennart25
Germany
Posts 46
Lennart25 replied on Thu, Jul 16 2020 1:43 PM
As Lawrence already mentionend, the Tonmeister and person in charge of sound design at B&O, Geoff Martin discussed this topic on his blog "earfluff and eyecandy" in i think even multiple posts. The most informative one on this matter is "what are subwoofers REALLY for?" (see below)
In the end it is up to you and i can very well understand the desire for a shaking room for movies. If you were to use this system for music however I would very much recommend to throw away the Beolab 2. No matter how well it performs, it will only interfere and distort the musical image those beautiful Beolab 5s create.
Is there the possibility to set up two "modes"? Stereo only for music and "all out" surround for movies?
https://www.tonmeister.ca/wordpress/2013/12/13/bo-tech-what-are-subwoofers-really-for/
alvinedyvane
Portsmouth
Posts 17
Thanks Lawrence
The set up was really more about the manual settings you can change once they have done their thing.
Thanks anyway.
alvinedyvane
Portsmouth
Posts 17
lawrencejmcook
Posts 742
alvinedyvane:
Thanks Lawrence
Thanks anyway.
Alvin, ask and ye shall receive:
https://bangolufsenassistentgohe.blob.core.windows.net/manuals/TELEVISIONS/BEOVISION%2011%20WITH%20BEO4/technical-sound-guide-1409%20(2).pdf
The BL5 doesn’t really have any manual settings, but the BV11? In spades!
The technical sound guide linked above is taken from the B&O support page for the BV11. It has been superseded, but this version has a very helpful matrix at the end that shows what effect bass re-direction will have on your subwoofer depending on what other speakers you have connected.
For completeness, though, here is the latest version of the TSG:
https://bangolufsenassistentgohe.blob.core.windows.net/manuals/TELEVISIONS/TECHNICAL_SOUND_GUIDE/technical_sound_guide_televisions_2004.pdf
Happy playing!
Lawrence
alvinedyvane
Portsmouth
Posts 17
Thanks Lawrence.
i am getting green lights on the sub and have played around everywhere in the BV11 but no sound from the Sub.
i am pretty sure when I used the BL 5 with a BV5 I think I had to change the speakers to a different model, the sub then kicked in.
Do you think I have to do the same with the 11?
alvinedyvane
Portsmouth
Posts 17
Thanks Lawrence.
lawrencejmcook
Posts 742
Hi Alvin,
Did you follow the instructions in the lower half of page 7 in the TSG (the first link in my previous post)?
Lawrence
Page 1 of 1 (11 items) | RSS
