Hey all.
I want to maximise the sound and film experience with my Beolab 5's and was wondering if any of you have a guide on how to best set them up.
I have obviously had a good play around but it is not clear on how to get the best bass out of them. I also have two 8000's for rear.
I also wanting to connect my Beolab 2 (I know what you are going to say) but once you connect the 5's the system somehow does not allow this. Is there a bypass or trick or am I doing something wrong?
Thanks all
Alvin
alvinedyvane:Hey all.I want to maximise the sound and film experience with my Beolab 5's and was wondering if any of you have a guide on how to best set them up.I have obviously had a good play around but it is not clear on how to get the best bass out of them. I also have two 8000's for rear.I also wanting to connect my Beolab 2 (I know what you are going to say) but once you connect the 5's the system somehow does not allow this. Is there a bypass or trick or am I doing something wrong?Thanks allAlvin
Great stuff Lawrence. I will try this as I did get the Sub working on the previous Beovison 5, it sounded great.
The speakers are self amped though right, so I wonder what the TV takes away or adds?
Is there anywhere on here that shows how best to set up the Beolab 5's with a Beovision 11? Would be good to make sure I have them set up right.
alvinedyvane:Great stuff Lawrence. I will try this as I did get the Sub working on the previous Beovison 5, it sounded great. The speakers are self amped though right, so I wonder what the TV takes away or adds? Is there anywhere on here that shows how best to set up the Beolab 5's with a Beovision 11? Would be good to make sure I have them set up right.
As Lawrence already mentionend, the Tonmeister and person in charge of sound design at B&O, Geoff Martin discussed this topic on his blog "earfluff and eyecandy" in i think even multiple posts. The most informative one on this matter is "what are subwoofers REALLY for?" (see below)
In the end it is up to you and i can very well understand the desire for a shaking room for movies. If you were to use this system for music however I would very much recommend to throw away the Beolab 2. No matter how well it performs, it will only interfere and distort the musical image those beautiful Beolab 5s create.
Is there the possibility to set up two "modes"? Stereo only for music and "all out" surround for movies?
https://www.tonmeister.ca/wordpress/2013/12/13/bo-tech-what-are-subwoofers-really-for/
Thanks Lawrence
The set up was really more about the manual settings you can change once they have done their thing.
Thanks anyway.
alvinedyvane:Thanks Lawrence The set up was really more about the manual settings you can change once they have done their thing. Thanks anyway.
Thanks Lawrence.
i am getting green lights on the sub and have played around everywhere in the BV11 but no sound from the Sub.
i am pretty sure when I used the BL 5 with a BV5 I think I had to change the speakers to a different model, the sub then kicked in.
Do you think I have to do the same with the 11?
