Besound 1 as remote control for Beosound Core?
jc
Posts 80
jc Posted: Tue, Jul 21 2020 9:31 AM
I'm new to the multiroom speaker approach from B&O. I have a BS Core and was wondering if I could use a BS1 (or any other of their multiroom speakers) as a remote control for the Core? So, e.g.: if the Core is playing music, while the BS1 is not, can I use the dial on the BS1 to control the volume or on/off of the BS Core?
(or do I really need to buy an Essence Remote for that or keep using the app?)
Thanks!
Millemissen
Flensborg, Denmark
Posts 14,680
Sorry for the answer - but that won’t be possible.
As you write, you ned aa remote coupledto the Core....or the Bang & Olufsen app on a mobile device.
jc
Posts 80
jc replied on Tue, Jul 21 2020 3:23 PM
Ah, that's a shame. I don't have a B&O TV anymore, so I don't have a BRone lying around. And not sure about the Essence.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Tue, Jul 21 2020 5:50 PM
jc:
The Essence remote is a very good Core companion. Where you cannot select precisely what you want to play, e.g a particular radio, track, album or playlist, you can easily control the sources you want to start, e.g. tap to join or start the latest played source, double tap to navigate in the configured local sources or join other experiences, move forward/backward in any playing list (music, radio), control the volume and shutdown all B&O devices when needed. All that in a small and nice object.
Jaffrey2230
Washington DC
Posts 520
The B&O App works very well with the Core. If you want, with iOS14, buy an iPod Touch, install B&O App and use it as a remote control. You don't need to turn on lock screen etc. IMHO it is better than the Essence remote (I have 2 cores and 2 essence remotes) because you can control the music sources more easily from the App.
Also, when I use the Essence remote, often when I long press to put the Core into stand-by the remote just goes into pairing mode and I have to re-pair the whole thing. No such issue with the App. If you can afford it (unfortunately it is out of my league), the Halo might be the best option...
B&O in my life 😊:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Wed, Oct 28 2020 6:45 PM
Jaffrey2230:
Are you long pressing the white or black disk of the remote?
Jaffrey2230
Washington DC
Posts 520
Is one the right one? I typically just press where the dot on top is (long press) and it sometimes will switch source and then go to sleep or sometimes go into pairing. It's one reason I switched to using the app to put the Core in standby. Should I be careful on which disk to press? thanks!
B&O in my life 😊:
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Thu, Oct 29 2020 11:40 AM
Jaffrey2230:
Ohhh yes
Little dark disk: short press = pause, long press = All standby
Little light disk: short press = resumes a paused source, navigates amongst local sources defined in the paired product, joins multiroom
experience. Long press = BT pairing
Jaffrey2230
Washington DC
Posts 520
thanks! I guess user error then Smile
B&O in my life 😊:
Page 1 of 1 (9 items) | RSS
