I'm new to the multiroom speaker approach from B&O. I have a BS Core and was wondering if I could use a BS1 (or any other of their multiroom speakers) as a remote control for the Core? So, e.g.: if the Core is playing music, while the BS1 is not, can I use the dial on the BS1 to control the volume or on/off of the BS Core?
(or do I really need to buy an Essence Remote for that or keep using the app?)
Thanks!
Sorry for the answer - but that won’t be possible.
As you write, you ned aa remote coupledto the Core....or the Bang & Olufsen app on a mobile device.
Ah, that's a shame. I don't have a B&O TV anymore, so I don't have a BRone lying around. And not sure about the Essence.
jc:And not sure about the Essence.
The B&O App works very well with the Core. If you want, with iOS14, buy an iPod Touch, install B&O App and use it as a remote control. You don't need to turn on lock screen etc. IMHO it is better than the Essence remote (I have 2 cores and 2 essence remotes) because you can control the music sources more easily from the App.
Also, when I use the Essence remote, often when I long press to put the Core into stand-by the remote just goes into pairing mode and I have to re-pair the whole thing. No such issue with the App. If you can afford it (unfortunately it is out of my league), the Halo might be the best option...
B&O in my life 😊:
Jaffrey2230:often when I long press to put the Core into stand-by the remote just goes into pairing mode
Is one the right one? I typically just press where the dot on top is (long press) and it sometimes will switch source and then go to sleep or sometimes go into pairing. It's one reason I switched to using the app to put the Core in standby. Should I be careful on which disk to press? thanks!
Jaffrey2230:Should I be careful on which disk to press? thanks!
thanks! I guess user error then
