Beogram 4002 Brushed Metal Strip Removal
This post has 10 Replies | 1 Follower
John Francis
USA
Posts 155
Silver Member
John Francis Posted: Fri, Aug 7 2020 12:20 AM
Hello All,
Has anyone found a successful way to remove the brushed metal strip from a Beogram 4002 dust cover without bending it?  I have a Beogram 4002 dust cover that I bought on ebay and was pretty excited to find it in such good condition, some normal scratches but nothing I couldn't sand and polish out. Unfortunately I discovered the plastic that the metal hinge attaches was broken on one side. I do have another dust cover which I was going to replace with the one from ebay. It would be really nice if I could get the good strip off and put on the other dust cover.
John
sonavor
Texas, United States
Posts 3,732
sonavor replied on Fri, Aug 7 2020 5:16 AM
Hi John,
Yes. Beolover recently posted a blog entry on how to do that.
-sonavor
John Francis
USA
Posts 155
Silver Member
Hello John,
Thanks for responding to my post and directing me to Beolover's blog entry. Looking at the process makes me consider if I have the courage to try removing the brushed metal strip on the good dust cover that I took so much time polishing. Putting it in the oven is the bit that makes me nervous. I will try taking off metal strip from the one on the cracked dust cover first and see how that goes.
Much appreciate your help.
John
Craig
Yarm, United Kingdom
Posts 2,040
Silver Member
Craig replied on Sat, Aug 8 2020 6:07 AM
There is a UK member of the site who can provide very good replacement aluminium strips for Beogram hoods.......can’t remember offhand what his name is but if you search he is out there 😉
Craig
Posts 2,040
Silver Member
Craig replied on Sat, Aug 8 2020 6:08 AM
Craig
Posts 2,040
Silver Member
Craig replied on Sat, Aug 8 2020 7:43 AM
John
I have sent you an email with the members email address if you choose to contact him
Craig
John Francis
USA
Posts 155
Silver Member
Hello Craig,
Thanks for the post, I do not however see an email from you with the contact. Could you please try again.
Thanks,
John
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Aug 8 2020 5:05 PM
Not all email servers will accept emails sent through from third party server.
Craig, I have emailed you Johns email-address.
Craig
Posts 2,040
Silver Member
Craig replied on Sun, Aug 9 2020 9:00 AM
Thanks for that........i have sent you an email John, there are two email addresses so send your request to both as I'm not sure Barrie monitors both boxes.
Craig
John Francis
USA
Posts 155
Silver Member
Thank you Craig!
John
musicismoving
Posts 21
Hello all, I am the member who can reproduce the the aluminium strip for the 4000/4002.4004 and 6000 turntables. I can emulate whatever lettering you have on your particular turntable. The finished item is next to indistinguishable from the original.
 Please drop me a message for your requirements.
Page 1 of 1 (11 items) | RSS
