When I play my BS9000, it functions normally, but when it reaches CD6 it has the following issue:
The sledge seems to stop a few millimetres offset, then it tries to adjust before it turns off. Sledge then returns to top position.
Is it doomed, or is there an easy fix for this?
I managed to fix this.
I opened it up, release the sledge, and then I moved it from left to right several times. It was giving a small resistance between position 5 and 6, so I moved it back and forth there several times.
Now it works like a charm again.
Have to admit that I was pretty sure I was making an expensive doorstop.
