Hi I am looking to purchase a record player to connect to my Beocentre 2300. I am looking for any suggestions as to which deck would be best for my unit, obviously sound quality us a must. I have a pair of Beosound 8000 mkii speakers connected to my 2300.
many thanks.
Any of the RIAA equipped decks will work well with your BC2300 - worth reading this FAQ to be sure: https://www.beoworld.org/faq_view.asp?id=18
I am now using a BG6500 (won here on Beoworld ) with my BC2300 - see photo below. I purchased an SMMC4 from Soundsmith to use with it. I can't really comment on the sound quality because I am only using a temporary setup (with an A2 Active providing amplification), but the remote functionality is great.
I am sure that other experienced turntable users on the forum with be able to suggest the best Beogram and cartridge combination. There is further advice about cartridges here: https://www.sound-smith.com/lookup/bo-cartridges
Hi Guy,
Many thanks for your response to my question. The link is very useful read.
kind regards
