Harmony 88
This post has 14 Replies | 1 Follower
Birder
Posts 7
Birder Posted: Sat, Sep 12 2020 10:36 AM
Hi all fellow beoworlders. A technical question for you technical knowhows.  I am considering a Harmony 88 but realize there is a mismatch between the HDMI version 2.1 on the ZX panel and the soundcenter wich has "only" version 2.0. Lets say 8K becomes relevant in 3-5 years and I want to take full advantage of 8K in 60 Hz which is available via the HDMI sockets on the panel; Will I have the full advantage of version 2.1 or will the soundcenter influence this by any means and keep my video signal at 8K 30 Hz? Making such a substantial investment, I want to be sure my Harmony can achive what the specs of the panel is able to deliver. Any other disadvantages of this "mismatch".  Thanks in advanca😊. Great Forum by the way.
Regards
Birder
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Sep 12 2020 11:33 AM
Birder:
Regards
Birder
you’re afraid you will not have 8K sound?Big Smile
Birder
Posts 7
Birder replied on Sat, Sep 12 2020 12:24 PM
Not at all Carolpa😁.  More than happy with the sound. Just want to be sure the soundcenter wont deteriorate the video signals that HDMI version 2.1 can handle.
Birder
Curly
FL, USA
Posts 366
Curly replied on Sat, Sep 12 2020 12:26 PM
Why or how does the sound center influence video at all on Harmony? I would imagine the TV panel plays video and is connected via HDMI to the sound center only for purposes of routing audio, not video.
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote
Previously: BeoSound 1 non-GVA
Birder
Posts 7
Birder replied on Sat, Sep 12 2020 2:44 PM
Thanks for the reply Curly. I hope and imagine that as well, just want to be convinced and sure.
Birder
Millemissen
Flensborg, Denmark
Posts 14,680
Curly:
Which would mean, that you would have to connect the source, that needs a 2.1 HDMI connection for full performance (whatever that would mean) to the LG part - and not via the Sound Center inputs.
And you will have to rely on CEC instead of PUC, if there is anything to control with the BROne.
Birder
Posts 7
Birder replied on Sat, Sep 12 2020 5:37 PM
Thanks Millemissen. Appreciated. The kind of answear and clarification i was looking for. For the part "whatever that would mean"; In this case it means 60 Hz of 8K rather than 30 Hz and frame by frame "Optimalization". You may argue 8K is not relevant for the foreseeable future but making such a heavy investment, I need to look 3-5 years into the future.
Birder
Mikipidia
Posts 2,169
Mikipidia replied on Sat, Sep 12 2020 6:21 PM
Iam not sure 8k will even be a thing by then. The amount of bandwith needed either for tv or through internet is insane for 8k 60hz. It’s literally 8x the data if you’re coming from 4k 30hz and more than 32x if you’re coming from 1080i 30hz(if iam doing the math rightStick out tongue). Not to mention what 5 years of use does to the PQ on a 2020 oled...
Personally I would love the idea more if LG made an 88” 4k panel at a more reasonable price than what they charge for the 8k variaty
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Millemissen
Flensborg, Denmark
Posts 14,680
It’s funny.
It is like when 4K first came out, people afterwards realized that the more important thing actually was HDR (HFR etc), from which a 2K panel would benefit essensially - and would demand far less bandwith streaming.
The chase for even more resolution only makes sense with bigger displays than an 88” imo.
The industry can produce the stuff.....and of course want to sell it.
The costumer must decide, whether he/she will be part of the race.
Birder
Posts 7
Birder replied on Sat, Sep 12 2020 10:07 PM
Mikipedia; wether 8K will be a thing or not by then remains to be seen. The important thing for me is to be at least up to the specs that the panel can offer today, then.
Millemissen; you are right,  8K resolution really only makes sense with very large displays, maybe even larger than 88" (depending on how close you you are to the screen).  But as I stated initiially; When and if 8K becomes relevant in 3-5 years; I cant afford to loose out on specs specified even now. 8K is comming even if you or I dont "need it". My profession is optometry and vision science and I firmly believe higher  resolution will bring on collateral benefits besides the very resolution.
Birder
Sandyb
Posts 2,186
Sandyb replied on Sat, Sep 12 2020 11:48 PM
HDMI 2.1 (the whole feature set) really is only relevant for gaming.
And a good subset of the 2.1 feature set is available on current TVs through their 2.0a / 2.0b implementation.
Gaming is the only place that content with the max resolution and high frame rates will become available.
So unless you're a gamer (and if you are, I suspect a Harmony may not be centre of your gaming rig), then you re not missing out on anything.
Its how many years since the advent of broadcast HD? Any even now, none of the broadcasters beam out in 1080P, i.e. the full feature set of HD.
If you like the Harmony, get it and dont stress about future proofing for an even now unlikely scenario. Or if you want to be as future proof as possible now, then I'd suggest buying such an expensive TV may not be the most sensible (of course I dont know your budgetary considerations).
Birder:
Birder
Emil Jensen
Denmark
Posts 766
Birder:
Regards
Birder
As the Soundcenter have eARC there is no problem at all. you will have 3 fully capable HDM input plus 4 other HDMI input.
If or when you will need the capacity of HDMI 2.1 you just plug it in the TV, and the sound will go uncompressed to the soundcenter.
I saw the TV in Hamborg, and you will surely have the best TV on the market good luck with that :D
Birder
Posts 7
Birder replied on Sun, Sep 13 2020 9:18 AM
/quote]
Quote
Hi Emil and thanks for the input. Exactly as I hoped then👌😊.
Birder
Millemissen
Flensborg, Denmark
Posts 14,680
It’s either you buy it now and enjoy it - or you wait........with the result that the industry by then has developed ‘new dazzling features’, that they will  tell you, that you absolutely need In order to get the best out of some certain games or demo videoes.
As of now and for some time you probably could connect a gaming console to the LG-tv itself - no PUC control needed there - with the sound routed to the Sound Center for the best possible solution.....and your peace of mind.
Birder
Posts 7
Birder replied on Sun, Sep 13 2020 10:50 AM
Very true Millemissen. I will purchase it in very near future😊🤞.
Birder
Page 1 of 1 (15 items) | RSS
