A hot BM5500
This post has 9 Replies | 1 Follower
madskp
Denmark
Posts 321
madskp Posted: Sun, Sep 13 2020 11:54 AM
I just aquired my parents BM5500. Noticing the heatsink was very hot even at idle and volume at 00. Have resoldered the relay on the PSU board as per suggestion i another thread, and when I was at it also resoldered all the power transistors.
Didnt make any difference though. The heatsink is to hot to touch on the left side seen from the front.
Any suggestions where to start?
madskp
Denmark
Posts 321
madskp replied on Sun, Sep 13 2020 11:56 AM
And by the way it is playing fine, just trying to avoid damage
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Sep 13 2020 2:30 PM
Replace the idle current trimmers and readjust the idle currents.
Do one channel at a time, beginning with the channel with the current highest idle current.
madskp
Denmark
Posts 321
madskp replied on Sun, Sep 13 2020 5:24 PM
Thanks for the input, just to be sure is it these two 100 ohms in the picture we are talking about?
Dillen
Posts 13,191
Dillen replied on Sun, Sep 13 2020 6:45 PM
Yes.
And the adjustment procedure is in the servicemanual.
While you are at it, I suggest you replace the black ROE caps too. They will be if not bad, then at least marginal by now.
madskp
Denmark
Posts 321
madskp replied on Sun, Sep 13 2020 6:55 PM
Ok, the servicemanual available here at Beoworld only contains the diagrams.
Do you know if its availible somewhere else?
Dillen
Posts 13,191
Dillen replied on Sun, Sep 13 2020 7:41 PM
For the idle current settings you can also use a Beomaster 5000, 6500 or 7000 servicemanual.
The amplifier is basically the same.
madskp
Denmark
Posts 321
madskp replied on Sun, Sep 13 2020 8:28 PM
Super, good to know Smile
madskp
Denmark
Posts 321
madskp replied on Fri, Sep 25 2020 6:53 PM
Replaced the ROE caps and the trimmers and readjusted as described in the servicemanual. Now I can almost not feel a temperature rise at the heatsink Smile
Also changed the trafo to 240V while I was at it.
Dillen
Posts 13,191
Dillen replied on Fri, Sep 25 2020 7:24 PM
Glad it worked out alright.
Good job! Yes - thumbs up
Page 1 of 1 (10 items) | RSS
