Problem with Beolab 5 room calibration system
Damir Grgic
Dubai, UAE
Posts 21
Damir Grgic Posted: Tue, Sep 15 2020 9:41 AM
The client has an issue with room calibration on Beloab 5:
The calibration mic comes out half way, then fully, then retracts again and gives a red signal light.
Any ideas what might be wrong and how to rectify it?
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Tue, Sep 15 2020 11:20 AM
Damir Grgic:
Sounds normal. Only when the red light is blinking, the servicetool can be used to read a possible failure.
CB
> You are Here <
Posts 1,762
CB replied on Wed, Sep 16 2020 7:05 AM
Damir Grgic:
But does he hear the calibration sound?
Is the problem with both BLs or just one?
If there is no sound, it is a hardware problem
If a sound is emitted and the red light is on on only one BL, then the calibration is not successful: try to move the cabinet which is too close to this BL, or try to turn the BL to avoid this cabinet
Page 1 of 1 (3 items) | RSS
