The client has an issue with room calibration on Beloab 5:
The calibration mic comes out half way, then fully, then retracts again and gives a red signal light.
Any ideas what might be wrong and how to rectify it?
Damir Grgic: The calibration mic comes out half way, then fully, then retracts again and gives a red signal light.
Sounds normal. Only when the red light is blinking, the servicetool can be used to read a possible failure.
Damir Grgic:The calibration mic comes out half way, then fully, then retracts again and gives a red signal light.
