Cannot find any information for the years that the joystick version was in production ?
Anybody know ?
Ken
Beo4 type 1710 intro: 2010Beo4 type 1712 intro: 2012
It was sold side by side with BeoRemote one until it was empty. It was also change from standard produkt nr to an spare part number in the end. So When the last beo4 left struer, its only B&O that know:)
BeoRemote one type 1716 intro 2014Beoremote one BT type 1717 intro 2016Beoremote one BT Netflix/Amazon type 1719 intro 2017 w34
Sorry not sure which one I have, I know its with a joystick.
Mk1 is with AV button
Mk2 with DVD button
Mk3 with DTV button
Mk4 Joystick ???
Mk5 ???
What is the differance between type 1710 and 1720
Sorry I mean 1710 and 1712
JKW TAYLOR:Sorry I mean 1710 and 1712 Ken
Beo4 type 1710 is introduce in 2010. then a smal upgrade in april 2012 with type 1712.
I cannot understand what new top plate is. So not realy sure what the different. Maybe only some smal change in the production with a new aluminium top plate you dont realy will see the different.
Sorry cannot help more=)
But Beo4 with the joystick is the last beo4 made. So if you think about your list with MK1, MK2 and so one. its a MK4. No more after that.
You have also the exclusive beo4 cinema for a period, that only was sold to smal dealer out there.
I seem to remeber seeing a hotel version as well.
Can de Beo4 control modern Bang & Olufsen products ? or is there a cut off date?
JKW TAYLOR: Can de Beo4 control modern Bang & Olufsen products ? or is there a cut off date? Ken
Since a Beo4 is ir-only, most new products can’t be controlled natively.
However, you can e.g. connect an ir-receiver to a BS Core (or even to a BL50/90) and use ir-control via Beo4/navi.
Please specify, what you aim for.
I know that the Beoremote one came out in 2015 and was IR & BT,
I just would like to know as I have a Beovision 7-40 mk5 and can use my Beo4 mk 4 to control my Tv and stereo.
f I upgrade to een a newer tv can I still control my older other B&O products, as I have read that the new beoremote is BT only ?
The first BeoRemote One (these are rare nowadays) was ir-only.
The current (including the one with Netflix/Amazon buttons) is ir and bt.
With the BROne, that you but new now, you can control both types - however you will have to switch mode each time you switch from old to new products.
it seems that the coming HaloRemote will not have any ir-capacity.
Are all B&O products from 2020 BT ?
JKW TAYLOR: Are all B&O products from 2020 BT ? Ken
If you count out these add-on receivers, yes!
And the BROne (still) has the ir-sender....oh, and the Essence Remote has support for ir, too.
OK tanks for all the information, good to see that the forum works.
What is the best, mk3 (DTV) or MK4 (Joystick) ?
What are the pro's and con's ?
Interesting, the big advantage of the Beo4 was that you could find the buttons in the dark.
Do you know why they changed the layout of some buttons for the Beo4 mk4 ?
Was there a reason ? List, Text, Stop, Exit, Play have all changed position.
Record has gone.
So I gather that the mk4 is used with a smart tv.
I have a 7-40 mk5 and 7-32 mk5 in the menu I can select the mk3 or mk4
They both have the Beo4 mk4 joystick, I just wonderd what the advantage is of the joystick version with these tv's ?
Depends... I have 6 Beo4 MK2/MK3 and got a MK4 .... I found it very annoying that they changed the placement of buttons next to the volume control.
When you are used to press stop/exit without looking at the remote I cannot recommend having both MK2/MK3 and the MK4 .
If you don't have a product where the navigation button is needed why consider the MK4
Go for BROne or MK2/MK3
Have got the mk 4 , but want to downsize.
Would it be better to sell the tv's with the mk3 or mk4 ?
Maybe keep the mk4's voor my next B&O tv ?
Just interested why Bang and Olufsen changed the layout ?
