Beo4 mk 5 joystick
This post has 20 Replies | 3 Followers
JKW TAYLOR
Nederland
Posts 140
JKW TAYLOR Posted: Tue, Sep 15 2020 2:25 PM
Cannot find any information for the years that the joystick version was in production ?
Anybody know ?
Ken
andybandy
Posts 164
andybandy replied on Tue, Sep 15 2020 9:47 PM
Beo4 type 1710 intro: 2010
Beo4 type 1712 intro: 2012
It was sold side by side with BeoRemote one until it was empty. It was also change from standard produkt nr to an spare part number in the end. So When the last beo4 left struer, its only B&O that know:)
BeoRemote one type 1716 intro 2014
Beoremote one BT type 1717 intro 2016
Beoremote one BT Netflix/Amazon type 1719 intro 2017 w34
JKW TAYLOR
Nederland
Posts 140
JKW TAYLOR replied on Wed, Sep 16 2020 11:59 AM
Sorry not sure which one I have, I know its with a joystick.
Mk1 is with AV button
Mk2 with DVD button
Mk3 with DTV button
Mk4 Joystick ???
Mk5 ???
What is the differance between type 1710 and 1720
Ken
JKW TAYLOR
Nederland
Posts 140
Sorry I mean 1710 and 1712
Ken
lawrencejmcook
Posts 742
JKW TAYLOR:
Ken
Hi Ken,
If you remove the Beo4 battery cover and batteries there should be a label with the Type No. / Serial No. in the battery bay.
There may be a way to see it on screen - perhaps andybandy knows.
Lawrence
andybandy
Posts 164
andybandy replied on Wed, Sep 16 2020 11:29 PM
Beo4 type 1710 is introduce in 2010. then a smal upgrade in april 2012 with type 1712.
I cannot understand what new top plate is. So not realy sure what the different. Maybe only some smal change in the production with a new aluminium top plate you dont realy will see the different.
Sorry cannot help more=)
But Beo4 with the joystick is the last beo4 made. So if you think about your list with MK1, MK2 and so one. its a MK4. No more after that.
andybandy
Posts 164
andybandy replied on Wed, Sep 16 2020 11:32 PM
You have also the exclusive beo4 cinema for a period, that only was sold to smal dealer out there.
JKW TAYLOR
Nederland
Posts 140
I seem to remeber seeing a hotel version as well.
Can de Beo4 control modern Bang & Olufsen products ? or is there a cut off date?
Ken
Millemissen
Flensborg, Denmark
Posts 14,680
JKW TAYLOR:
Ken
Since a Beo4 is ir-only, most new products can’t be controlled natively.
However, you can e.g. connect an ir-receiver to a BS Core (or even to a BL50/90) and use ir-control via Beo4/navi.
Please specify, what you aim for.
JKW TAYLOR
Nederland
Posts 140
JKW TAYLOR replied on Thu, Sep 17 2020 12:18 PM
I know that the Beoremote one came out in 2015 and was IR & BT,
I just would like to know as I have a Beovision 7-40 mk5 and can use my Beo4 mk 4 to control my Tv and stereo.
f I upgrade to een a newer tv can I still control my older other B&O products, as I have read  that the new beoremote is BT only ?
Ken
Millemissen
Flensborg, Denmark
Posts 14,680
The first BeoRemote One (these are rare nowadays) was ir-only.
The current (including the one with Netflix/Amazon buttons) is ir and bt.
With the BROne, that you but new now, you can control both types - however you will have to switch mode each time you switch from old to new products.
it seems that the coming HaloRemote will not have any ir-capacity.
JKW TAYLOR
Nederland
Posts 140
Are all B&O products from 2020 BT ?
Ken
Millemissen
Flensborg, Denmark
Posts 14,680
JKW TAYLOR:
Ken
If you count out these add-on receivers, yes!
And the BROne (still) has the ir-sender....oh, and the Essence Remote has support for ir, too.
JKW TAYLOR
Nederland
Posts 140
JKW TAYLOR replied on Mon, Sep 21 2020 10:23 AM
OK tanks for all the information, good to see that the forum works.
Ken
JKW TAYLOR
Nederland
Posts 140
What is the best, mk3 (DTV) or MK4 (Joystick) ?
What are the pro's and con's ?
Ken
Fansastic
The Hague, The Netherlands
Posts 768
The Beo4 with joystick was designed for use with the new generation Beovision 11/V1 and Beosystem4 (BV12). it is used to scroll through the menus and press to select.
The older Beo4’s do not work with this generation (scrolling a.o.)
Apart from that there is no functional difference
JKW TAYLOR
Nederland
Posts 140
Interesting, the big advantage of the Beo4 was that you could find the buttons in the dark.
Do you know why they changed the layout of some buttons for the Beo4 mk4 ?
Was there a reason ? List, Text, Stop, Exit, Play have all changed position.
Record has gone.
Ken
Fansastic
Posts 768
As said the Beo4 was adjusted for use with new Beovision interface in that time. This required some other rearrangements of button’s also.
If you do not have the Beovision then you are best of with the version without the joystick
JKW TAYLOR
Nederland
Posts 140
So I gather that the mk4 is used with a smart tv.
I have a 7-40 mk5 and 7-32 mk5 in the menu I can select the mk3 or mk4
They both have the Beo4 mk4 joystick, I just wonderd what the advantage is of the joystick version with these tv's ?
Ken
Ravsted
Denmark
Posts 345
Ravsted replied on Fri, Nov 6 2020 7:53 PM
Depends... I have 6 Beo4 MK2/MK3 and got a MK4 .... I found it very annoying that they changed the placement of buttons next to the volume control.
When you are used to press stop/exit without looking at the remote I cannot recommend having both MK2/MK3 and the MK4 .
If you don't have a product where the navigation button is needed why consider the MK4
Go for BROne or MK2/MK3
JKW TAYLOR
Nederland
Posts 140
Have got the mk 4 , but want to downsize.
Would it be better to sell the tv's with the mk3 or mk4 ?
Maybe keep the mk4's voor my next B&O tv ?
Just interested why Bang and Olufsen changed the layout ?
Ken
Page 1 of 1 (21 items) | RSS
