Beolab 50 are a nightmare.
This post has 56 Replies | 2 Followers
Beofile7
Posts 150
Beofile7 Posted: Sat, Sep 26 2020 3:59 PM
I have had these speakers for 18 months. When they work they work fine. But honestly.. what a nightmare to own! I cannot go one week without having to reboot them. Everything fails constantly. I just want my previous life back!
Beofile7
Posts 150
Beofile7 replied on Sat, Sep 26 2020 4:05 PM
So after a reboot I just counted 11 times I had to hit the Beolab 50 icon on the app before it recognised them! That is usual.
Curly
FL, USA
Posts 366
Curly replied on Sat, Sep 26 2020 4:37 PM
Just curious, my friend, have you ensured you’re running the latest firmware on both the parent and child speaker?
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote
Previously: BeoSound 1 non-GVA
Michael
Sweden
Posts 2,578
Michael replied on Sat, Sep 26 2020 4:44 PM
I’ve had mine for a few weeks now, my friends have had them for years. I haven’t had any issues except for the app not responding two times but the speakers have been working well.
I enjoy them a lot. Maybe yours are faulty? Or your connections are not correct perhaps?
Beofile7
Posts 150
Beofile7 replied on Sat, Sep 26 2020 5:24 PM
They are hard wired to a Beosystem. But I regularly use them through BV11 wireless. But then everytime I power them back again a few days later,,, nothing. No config makes any difference. The only solution is to unplug, wait, and start again. That is so impressive, not!
Sweden
Posts 357
Silver Member
Martin replied on Sat, Sep 26 2020 6:20 PM
Hi Beophile
my first pair was a nightmaire. But I had them three month and after that I got a replacement. After that they work fine also with the new sw 3.1. BO have had trouble with some abL 50 and they know it very well! So try to change the speakers for new ones. I think that is the only solution.
Best regards
Sweden
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only),  Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Michael
Sweden
Posts 2,578
Michael replied on Sat, Sep 26 2020 6:54 PM
Beofile7:
It’s a bit sad seeing headlines like nightmare because it will then become the google headline and I don’t want that for B&O... I NEVER use wisa wireless because it’s simply really bad. It’s not designed for everyday home usage and even airplay suffers in dence radio areas.
Just stop using wireless now! I mean it. Underline it.
Also, bl50 looses a lot of its competence in wireless mode as the speakers can not communicate then. So please. Stop using it.
Esax
Posts 323
Esax replied on Sat, Sep 26 2020 6:55 PM
Just sell them. Someone will take the ***.😂
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
moxxey
South West, UK
Posts 5,359
moxxey replied on Sun, Sep 27 2020 9:23 AM
Michael:
That applies to most speakers, but perplexes me anyone would spend £20K+ on a speaker and then attempt to use a wireless connection to stream high quality audio from their TV to the speakers. The logistics and bandwidth required for this to work flawlessly is almost incomprehensible. I'd never connect a soundbar wirelessly to a TV, for example.
As a comparison, you can blind-stream radio or Spotify wireless to, say, an Edge or BeoSystem 2, and this generally does work flawlessly as it buffers the audio and you don't need to worry about sync. I've lost my internet connection a few times, yet the audio will carry on streaming for another 30 seconds as it was buffered.
When you connect your TV wireless speakers, you need perfectly streamed non-buffered flaw-free audio. And if you play an uncompressed Blu-ray audio feed, wirelessly, you're simply asking for issues.
I wonder if people really understand the technical barriers required to wirelessly stream audio?
Duels
England
Posts 2,553
Duels replied on Sun, Sep 27 2020 9:31 AM
I also recommend using cables rather than WISA.
I cabled my BL18s and 19 about six months ago and haven’t looked back since.
Purchased the cables from Steve naturally.
Beofile7
Posts 150
Beofile7 replied on Sun, Sep 27 2020 12:06 PM
I think there is a little misunderstanding here...
They are hardwired to a 7000 system but with a bit of switching I can also wirelessly use them as TV speakers. Both work well, once working.
I don't think I have ever had an issue driving them once the connection has been made.
The issue is the app losing it's connectivity occasionally....like every week! Often accompanied by just one speaker switching on! They are ALWAYS switched on via the 7000. ie. the wired connection.
So I switch on with "radio" and they power up, but the app does not connect so I lose all the app functions and cannot then drive them from the TV wirelessly as I cannot make that switching.
A reset of the iphone or using an ipad makes no difference. The speakers must be rebooted. I can find no other way.
So this is happening every few days. I hope this explains the issue a little further?
Aussie Michael
Melbourne, AU
Posts 3,730
Deleting as i think we were typing at the same time and i read your response Beofile., they are hard wired.
Jaffrey2230
Washington DC
Posts 520
Sorry. my response was not relevant to your issue.
B&O in my life 😊:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
Michael
Sweden
Posts 2,578
Michael replied on Sun, Sep 27 2020 6:42 PM
Beofile7:
With a bit of switching you can use them wireless? How?
Beofile7
Posts 150
Beofile7 replied on Sun, Sep 27 2020 6:51 PM
I change the sound on the BV11 to wireless BL 50 and the input to the speakers to wireless via the app. Obviously this will need to be pre-programmed.
Michael
Sweden
Posts 2,578
Michael replied on Sun, Sep 27 2020 7:22 PM
Beofile7:
Ok so you do use WISA? The thing we all have said is unreliable. I have had only issues with it on all the wisa speakers B&O makes.
But your problems might be something else. Are you also using WiFi for the app or at least a cable for that?
bwest1000
Posts 52
bwest1000 replied on Mon, Sep 28 2020 12:10 AM
So ... pay 30-50 k for speakers but don't use one of their selling points?  That's ludicrous.
Jaffrey2230
Washington DC
Posts 520
To be honest if WISA is probably not a good reason to buy beolab 50s. My 2 cents. It should be the audio quality and design.
B&O in my life 😊:
MaxH
Posts 126
MaxH replied on Mon, Sep 28 2020 11:51 AM
Never had a moment's problem with mine and since switching them to rear speakers via WISA I have  never had a dropped connection.
Michael
Sweden
Posts 2,578
Michael replied on Mon, Sep 28 2020 12:13 PM
bwest1000:
I wouldn’t say a selling point mainly is wisa, it’s simply a technology B&O incorporates in their speakers and it’s not recommended by anyone. Everyone suggest using cables. In the case of beolab 50 they don’t even work properly if used in wisa as the Dsps can not talk to each other then. This means that room compensation etc does not work properly. I read somewhere that the features are halved in function if wireless.
I would rather say that wisa is like putting a towbar on a rolls Royce. You probably would not.. at least that’s not why you would buy one.
Beofile7
Posts 150
Beofile7 replied on Mon, Sep 28 2020 1:42 PM
"So ... pay 30-50 k for speakers but don't use one of their selling points? That's ludicrous."
I completely agree and can't understand why some are eager to just overlook such a detail. To me it would be comparable to finding the rear doors on my Rolls Royce don't open! Sold as a four door but not all actually work!
But this is not about the wireless capabilities.
Mine are fine once connected. It is the speakers dropping connectivity with the app and refusing to re-establish without a reboot, whilst using wired connection. It is the only way I can turn them on. The app never turns them on. I don't know if it is supposed to?
Mikipidia
Posts 2,169
Mikipidia replied on Mon, Sep 28 2020 1:51 PM
What SW are you on and are you wired for internet or wiresless?
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Beofile7
Posts 150
Beofile7 replied on Mon, Sep 28 2020 2:27 PM
Wireless connection and s/w 2.3.4
Razlaw
Posts 4,345
Razlaw replied on Mon, Sep 28 2020 2:44 PM
Beofile7:
Do you mean trying to directly turn the 50s on from the app does not work as opposed to turning them on from a music source?
When I was on version 2.3.4 I could not turn the 50s on directly from the app if connected by WiFi, but could turn them on directly if connected by ethernet. I am now on version 3.0.0.
Have not tested it with 3.0.0 as I have no reason to turn them on other than letting the source turn them on.
Michael
Sweden
Posts 2,578
Michael replied on Mon, Sep 28 2020 3:05 PM
Beofile7:
Honestly I dont agree at all. As I have tried to explain, and asked during my try at finding the issue, the only problem I can see that causes these issues is the wireless part. We have already many times over at the forum established that WISA simply is not a very problem free solution. It is very easy to have issues with it. It uses the 5GHz radio of the wifi frequency range and if you have ANY other devices transmitting data on that range then you WILL have issues. And even if you don't it is fairly unstable at operating as it has to both transmit sound in near real time with a very low buffer and high quality sound as well as communicate turning on and turning off.
We do not know how the scenario in your home looks like but if the distance is more than a few meters and you have a regular router and multiple wireless devices I think that it already is a troublesome environment. If you live in a bank vault without wifi then maybe it WILL work. However, it is pretty usual that it does NOT work well.
And, besides that, your setup is fairly unusual as the speakers are connected to a vintage system and wirelessly to a modern system. I don't know how this works in tandem and its probably pretty rare to have this setup. I believe your speakers are connected to a wired router but I can't really tell from what you write but I hope they are. In any case, maybe there is also a problem with the router or how it routes/manages devices on the network, especially devices in idle mode. As you say you have problems turning the speakers on and off via the app.
I would go through all the details more thoroughly to find the issue. It might be your specific speaker/speaker that is the issue, a cabling issue, a router/router software or config issue, wifi issues or wisa issues, or compatibility issues with using a vintage system with powerlink and a TV via wireless config.
Anyway, I would not say the speakers are a nightmare. For me they sound really good, and are a very unique product. It is almost like a formula 1 car. Very high performance, very few devices and very custom made. It is probably possible to drive one of them on gravel but I dont think its a good idea either. Just like using wisa on these speakers, honestly I think B&O should not have included it but I guess marketing wanted it thrown in.
One thing that I am surprised with is that WIFI is always on in them, continuously pulling power and being mainly on without any reason when not in use. That is bad programming and probably a result of no customer input or complaints.
AnalogPlanet
Vienna, Austria
Posts 678
Thank God I don't have 50K to spend on a pair of speakers, but the fact is that every single thing I bought from B&O had some kind of wireless/BT connectivity issue. (Moment, A9, headphones etc).
bwest1000
Posts 52
bwest1000 replied on Tue, Sep 29 2020 12:03 AM
No way is that reasonable.  Your analogy doesn't really hold up.  To fit in to your analogy, let me say it is like buying a formula one car but being told not to use the highest gear.  It's like buying a Tesla that is self driving but being told the car is great but don't use the programming.  Or a new Porsche with wireless Carplay but then be told, "Well, yeah it's wireless carplay but it doesn't work.  Use a wire."  A Porsche apologist would say, ok, you gotta use a wire.  I love Porsche and am going to look the other way.  An unbiased consumer would hopefully demand a product that works as DESCRIBED!  If it doesn't work take out the feature then!  Take out a feature if it doesn't work!  I have 5 tvs, 3 playstations, a half dozen ipads and other apple devices, probably a dozen, amazon alexas and google chromes, nest systems and 40 LIFX bulbs and everything is working fine.  F-I-N-E.  So you're saying that its ok for the programming, wireless and WISA not to work from B&O?  Saying it is acceptable?  Take the feature out!  Don't put a non functioning feature in the marketing materials as a selling point.  I have bought used 8000s and 6000s and I am not complaining that their wireless functionality doesn't work because I know it is not there!  Dont sell me something with a feature that blatantly doesn't work.  It is literally the definition of a false bill of goods.
Michael
Sweden
Posts 2,578
Michael replied on Tue, Sep 29 2020 8:57 AM
bwest1000:
I can’t even read what you write. Use some formatting please.. is everyone just upset? We have all just said wisa is usually not working well and still all the focus is on insisting to use it.
B&O themselves even does recommend not to do it as it heavily limits the speakers performance. It’s also a feature that heavily relies on the surround of the speaker and not just the speaker itself.
Very hard to argue when people refuse to listen or even care.
The wireless interface is there but it is simply the worst one available.
I also said they should not have included the feature, please read. And now go enjoy your five TVs and dozen iPads. (Whatever that has to do with this...)
Millemissen
Flensborg, Denmark
Posts 14,680
I could imagine using WiSA for connecting a set of the 50’s as surround speakers.
But, I would never use WiSA if they were my front speakers intented to be used for 2 channel/stereo listening also or as a standalone pair with e.g. a Core/Moment.
moxxey
South West, UK
Posts 5,359
moxxey replied on Tue, Sep 29 2020 9:17 AM
bwest1000:
It's more of a technical issue. WISA is fine for streaming audio which doesn't need to be in sync with the video, but beyond this, I'd never try and WISA a 4K disc movie, with uncompressed audio, to my speakers, for example.
People don't get the technicalities and just blame B&O and the fact the speakers are 'so expensive it should work out the box!!!'. I can understand why some people buy B&O. Limited clue.
Sandyb
Posts 2,186
Sandyb replied on Tue, Sep 29 2020 9:19 AM
Not sure if people are upset or not, but possibly confused would a better adjective.
I think there is consensus that WISA connection is not preferable to wired.
I cant tell if there is consensus that WISA connection just doesnt work, or whether its a bit sketchy like many wireless tech?
And do B&O actually tell customers to avoid using WISA? If so, then that would be odd, and I can see why some are confused.
But again, its not obvious to me that there is a clear steer from them to avoid using it.
Michael:
bwest1000:
Michael
Sweden
Posts 2,578
Michael replied on Tue, Sep 29 2020 10:41 AM
Sandyb:
Well, WISA is extremely low latency wireless protocol based on 5ghz and if other transmissions occur there it will cause gaps that makes it immediately unreliable.
Getting wisa to work well means isolating the home from other transmission on this field and hoping for the best, placing the speakers in a distance that is optimal etc.
But, in wisa mode they are purely wireless and the dsp will work much worse as the two speakers can not communicate with each other using wisa. This is not beneficial in beolab 50 and hence should just be used as a last resort.
I don’t understand why it’s implemented in them either. Some people have no issue with it and some have a lot of issues with it. I have tried it and it worked 70% of the time with my beolab 20 but I gave up as it was very unreliable.
As for apple, airplay 2 also suffers when there is a lot of transmissions at once. I have had multiple issues of stutter as other problems related to high noise level radio environment and I prefer to stream by cable or make sure that the airplay decide (usually an iPad or iPhone) is alone doing heavy data transfer at once.
Mikipidia
Posts 2,169
Mikipidia replied on Tue, Sep 29 2020 12:57 PM
@beofile7
Could you try hardwiring in the 50’s for ethernet, even if just temporary, and see if that changes anything? It did for me. New SW is around the corner which should make a big difference, or reach out to your dealer and see if he can get it for you already?
Beofile7
Posts 150
Beofile7 replied on Tue, Sep 29 2020 4:33 PM
Mikipidia... Well I am tempted to try this, with wires laid all over the sitting room.? For what though? Maybe I'll post later on that. But thanks for a constructive contribution.  BUT... twice now, I have tried to steer (unsuccesfully) this conversation away from wireless comms. We are connected with wires. As far as I know, i cannot connect my iphone/ipad via a wire to these speakers? So that connection will always remain wireless? That is how they are designed to be operated, isn't it?
But for the benefit of those still arguing about wireless connections....B&O describe them as "seamless immaculate wireless connection"  I can't argue with that. AGAIN, I stipulate that once connected I have no problem. MY WIRELESS CONNECTION WORKS FINE. IT ALWAYS DID AND STILL DOES. So why are you alll arguing about this?
This is the issue...... I was listening to a CD wired via powerlink (that has not changed over the years as far as I know?) yesterday. Today, when I try to listen to another CD (again wired) the speakers do not switch on. They do not recognise an input signal. The app does not see the speakers at all.
That did not happen yesterday but it is happening occasionally. AFAIK it has nothing to do with any wireless comms?
Mikipidia
Posts 2,169
Mikipidia replied on Tue, Sep 29 2020 5:02 PM
I meant a cat5e/6 cable from your router to the master 50. I don’t think your issue is WiSa, it’s probably a mix of WiFi and the app. I used to have issues connecting the app to the speakers when they were on wifi. Once wired that went away for 95% of the time, the rest was the app i think.
So your phone being on wifi is fine, just try your 50’s connected to the router your phone is connected to via a cat cable.
Razlaw
Posts 4,345
Razlaw replied on Tue, Sep 29 2020 6:33 PM
Please forgive me if I am misunderstanding your problem, and perhaps I am not even understanding correctly what I am going to suggest....and Mikipidia knows far more than I do......but in addition to what he suggests, ...
If I understand your problem correctly, you are using both WISA to the speakers and PowerLink. The problem you mentioned is starting a CD by PowerLink but it not working the next time. Could page 37, paragraph 12.4 of the Technical Sound Guide possibly provide any help?
Beofile7
Posts 150
Beofile7 replied on Tue, Sep 29 2020 7:45 PM
I think not. They are set to recognise an auto input. And most of the time they do.
"Note that the Detection Threshold parameter is not available for the Power Link input, since the loudspeaker is automatically turned on and off by the Power Link source."
So this is non ajustable.
Mikipidia
Posts 2,169
Mikipidia replied on Tue, Sep 29 2020 9:41 PM
One thing with WiSa is that if you set them to WiSa they will ignore cabled connections all together and vice versa. If they’re set to auto detect wired sources they will not pick up WiSa sources. You’ll have to switch that manually in the app everytime you switch between the 2.
bwest1000
Posts 52
bwest1000 replied on Wed, Sep 30 2020 1:04 AM
Please excuse my formatting, English is my first language.
My example of multiple TVs and iPads is that I own other products from other brands that are more reliable and dont cost as much as a new car.  All of them are interacting and interfacing as described by the brand when sold.  This is their webpage, " Meet a wireless loudspeaker that performs beyond reference in every listening scenario. "  It doesn't do that.  It doesn't do what it says it will do.  It doesn't perform beyond reference in every scenario.  It has serious issues connecting via its wireless format.  You're agreeing with that.  You're defending a defective feature of a $40,000 pair of speakers.  This product touts itself as wireless in the first line of the overview of their product, right on their website under "Luxurious Beast".  You are saying it is defective.  The product has a defective feature.  A $40,000 pair of speakers has a defective feature.  A feature that remains defective.  It is a primary selling point of a 40k pair of speakers.  A defective feature is a primary selling point of a 40k pair of speakers.  Something seems off about selling a 40k pair of speakers with that as the primary selling point but yet the feature is defective.
Mikipidia
Posts 2,169
Mikipidia replied on Wed, Sep 30 2020 1:19 AM
WiSa due to the format only works as well as the frequency bands are empty. Not all routers adhere well the the 5ghz band and a fair few push over 5.2ghz which starts to be close to the WiSa range. What ever anyone says, WiSa works fine but isn’t optimal. Wired does 24bit 192khz, WiSa maxes out at 24 bit 96khz. And it has an effect on the room compensation.
In most cases people that buy these speakers don’t have 20+ networks with in range so in most cases it’s fine. I fall in the catagory of having 20+ networks in range and my bl17’s are on WiSa and they’re fine doing that for 99% of the time.
Page 1 of 2 (57 items) 1 2 Next > | RSS
DigiCert Secured Site Seal
