BeoLab 4000 mkII schematics
This post has 9 Replies | 2 Followers
Retro-Repair / Richard
Maastricht (Netherlands)
Posts 4
Retro-Repair / Richard Posted: Tue, Oct 6 2020 8:23 AM
Dear all,
I have a pair BeoLab 4000 mkII speakers that have a problem. I downloaded the Service Manual but unfortunately no schematics, only a block diagram. Is there perhaps someone that can help me with the schematics of these BeoLab 4000 mkII speakers?
Thank you,
Richard
marexy
Posts 710
marexy replied on Tue, Oct 6 2020 2:44 PM
Hi
There is no service manual with shematics.
The same goes for BL4.
What is the problem?
Tassos
Athens
Posts 323
Tassos replied on Tue, Oct 6 2020 6:24 PM
retrorepair:
Dear all,
Thank you,
Richard
I have schematics but of mki, I think the only difference is that mkii has class d amps whereas mki has ab class. If you want I can send them to you via email
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Oct 6 2020 8:04 PM
MkI and MkII are far from identical. In fact they are quite different.
Posts 4
Besides a small humming sound in both, one speaker makes a cracking noise...but not always. Sometimes it plays for minutes without any disturbances.
marexy
Posts 710
marexy replied on Thu, Oct 8 2020 12:07 PM
May be bad solder joint or amplifier PCB.
Posts 4
That solved it! A bad solder joint on the main PCB. Thanks a lot!
Regards,
Richard
Jekame
Posts 4
Jekame replied on Wed, Feb 16 2022 5:51 PM
Ik heb hetzelfde probleem wat hoe zag het er uit de slechte soldeer verbinding ?
gr Jef
Posts 4
Hallo Jef,
De slechte soldeerverbinding was optisch niet te onderscheiden van de goede soldeerverbindingen. Door met een multimeter diversen SMD weerstanden door te meten kwam ik toevallig op een weerstand waarvan de gemeten waarde behoorlijk afweek van de aangegeven waarde. Nadat de soldeerverbindingen opnieuw waren gedaan, gaf de weerstand de juiste waarde weer aan en was daarmee ook het probleem verholpen.
Groet,
Richard
Retro-Repair
Jekame
Posts 4
Jekame replied on Thu, Feb 17 2022 6:10 PM
dank voor je reactie en moeite
 de aangegeven waarde heb je van de SMD zelf ?   of heb je een overzicht
Veel vragen maar ik probeer een helder beeld te krijgen van waar te zoeken
Page 1 of 1 (10 items) | RSS
DigiCert Secured Site Seal
