Hi all,
I have my Beolab 50s connected to Beosound Core.
However, when the music is not playing, I could hear a noticeable hiss coming from the tweeters.
When I’m using USB audio connected to my Mac, there’s no hiss.
Is this supposed to happen?
thanks
Ray
wanc1:Hi all, I have my Beolab 50s connected to Beosound Core. However, when the music is not playing, I could hear a noticeable hiss coming from the tweeters. When I’m using USB audio connected to my Mac, there’s no hiss. Is this supposed to happen? thanks Ray
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Via Powerlink
wanc1: Via Powerlink
The Core shall be connected by optical to Beolab 50 for optimal sound. It can be connected via Powerlink but will then suffer from lower processing quality from the speakers internal DAC. This is a design choice (although stupid, as it can not be regulated).I would suggest you connect it over optical instead. It is possible that the sound you hear are a result of using an unshielded or badly shielded cable of low quality between the devices. You need a S/FTP Cat6 or 7 cable for optimal signal transfer without balancing or interference issues.
Well - all ‘ways into’ the 50’s are basicly treated the same way in the processing of the speaker/s with the exception that the analog connection runs through an ADC-converter.
When you connect a source analog you will have a slightly higher noice floor, that you can measure, but hardly hear.
I’d suppose that the (quality of) the used PL cable primarily is the reason for the ‘noticable hiss’.
Wouldn't it be fantastic that when you buy a pair of a 25.000EUR speakers, you get as well specifically instructed how to achieve the best sound quality? So that you don't have to reach out to this forum? Or is that too much to expect? (this is not the first thread with the same subject, right?)
Probably. Kinda disappointing though since the cables are installed by my dealers and are I guess “official” B&O ones. Will check out some optical cables.
True. In my country, it’s around 35000 euros... RIP
Risky to install? Also the sound guide is freely available
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Mikipidia:Risky to install? Also the sound guide is freely available New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0 Mikipedia on YouTube (finally ) https://www.youtube.com/c/Mikipedia Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
All Beolab speakers hiss.
L1NO:All Beolab speakers hiss.
Correct. The noise floor is lower with optical in and out from BS Core based on my experience as well. It’s highest with volume control audio out from a TV.
B&O in my life 😊:
I agree.
In my Core setup, I prefer using Toslink since the glass fibers aren’t susceptible to EMI like copper Powerlink cables are. I’ve noticed less feedback (I.e., hissing) issues when using Toslink versus Powerlink. That is to say, my Toslink cables don’t hiss at all.
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote
Previously: BeoSound 1 non-GVA
Curly:I agree. In my Core setup, I prefer using Toslink since the glass fibers aren’t susceptible to EMI like copper Powerlink cables are. I’ve noticed less feedback (I.e., hissing) issues when using Toslink versus Powerlink. That is to say, my Toslink cables don’t hiss at all. Currently: BeoSound Core, BeoLab 17, BeoLab 18 Previously: BeoSound 1 non-GVA
