How to open up a beocord 3500?
This post has 4 Replies | 0 Followers
Liljewall
Posts 5
Liljewall Posted: Thu, Nov 5 2020 1:00 AM
Hello!   Im trying to locate a problem i have with my beocord 3500 cassett player.
I have removed the glass front panel  and unscrewed 3 screws from under the touch glas panel.  also the screws on the back.  but i dont dare too use more force to remove the topp.  It still sits in its place..  Cant find a single good video on the internet either  that shows how to do.  Anyone here who have done this before that maybe wanna be specific what to do here :)
I want to get to the drivelines to the cassett driver wheels. I thinks maybe the drivelines are broken. because the wheels wont spin when you press play
Thanks in advice.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Nov 5 2020 11:44 AM
Open the lid using the motor drive.
Lift out the two small claws (see photo) - only just enough to allow the lid to slide up and off.
Liljewall
Posts 5
Great thanks for that helpful picture!
Now, i think i have solved the problem. found a rubberband on the bottom plate. that had fell of the driving wheels.  i have now put it in place again. but its hanging very loose. should it do that ? or do i need a band that is more thight?
Here is a picture of it when i place the rubber band into place again.
Dillen
Posts 13,191
Dillen replied on Thu, Nov 5 2020 2:53 PM
Yes, definitely a wrong or bad belt.
New correct parts are available from www.beoparts-shop.com
Liljewall
Posts 5
Thank you for that!  i ordered one right away!
While making that progress i did encounter a new problem. I opened up the gear that connect to the motor for the lid.  But now when im trying to assembly that thing i just cant get the peices to fit. I opened up my beograf cd that has the exact same solution for the lid opener and looked at that one. I know were the peices should be  but they just dont fit.. I have been trying to assembly this the whole day now.. Is there any info out here that can show more exactly how to put all the things together right?
I cant find any info at all.
After 2 days of figuring how the mechanics should work on the opening mecanism i found out that the metal arm that is supose to move the plastic wheel that is attached to the lid is supposed to clip around the plastic wheel... DOH!
Page 1 of 1 (5 items) | RSS
