Speaker Repair
This post has 15 Replies | 0 Followers
Bronowski
Posts 15
Bronowski Posted: Fri, Nov 13 2020 6:00 PM
I recently bought a vintage B&O system from 1988. The speakers distorted at high volume/frequency which I largely fixed with new contacts to the amp and new wiring. I still have a residual distortion which is not too  surprising after 32 years. Can anybody suggest where I can obtain repair/replacement kits. Units are 5" and 3" from passive panel speakers.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Nov 13 2020 6:37 PM
Which model of speakers are we talking about?
Bronowski
Posts 15
Bronowski replied on Fri, Nov 13 2020 8:57 PM
Beolab 3000 Passive
Bronowski
Posts 15
Beolab 3000 Passive
Dillen
Posts 13,191
Dillen replied on Fri, Nov 13 2020 9:58 PM
Beolab models are not passive.
Bronowski
Posts 15
Bronowski replied on Fri, Nov 13 2020 10:56 PM
I'll need to do a bit more research on the exact model. There's no marking on the speakers themselves so I'll attach an image.
Alex.
Bronowski
Posts 15
Bronowski replied on Sat, Nov 14 2020 11:16 AM
Second image to follow.
Bronowski
Posts 15
Bronowski replied on Sat, Nov 14 2020 11:27 AM
Bronowski
Posts 15
Bronowski replied on Sat, Nov 14 2020 11:36 AM
Bronowski
Posts 15
Bronowski replied on Sat, Nov 14 2020 11:39 AM
Images pasting onto here but not appearing on post. Need to try something else.
Alex.
Bronowski
Posts 15
Bronowski replied on Sat, Nov 14 2020 11:48 AM
Speakers are rectangular, 45cm wide by 38cm high.Metal plate 15cm wide extends on left or right side depending on speaker. Rest of area covered by removable fabric cover under which are the 3" (top) and 5" speaker unifts. They are wall mounted and came with a mounting strip. They are from 1988. I'll try to find a photograph online.
Alex.
Bronowski
Posts 15
Bronowski replied on Sat, Nov 14 2020 11:53 AM
I've found a photograph on ebay which calls them
Bang and Olufsen B&O Beolab 3000 passive Loudspeakers
Dillen
Posts 13,191
Dillen replied on Sat, Nov 14 2020 11:53 AM
They are the newest version of Beovox 3000 (Type 6716).
Check carefully that the woofers cones move without rubbing.
Capacitor kit for the crossover filters here:
https://www.beoparts-shop.com/product-category/beovox/beovox-3000-type-6716/
Bronowski
Posts 15
Bronowski replied on Sat, Nov 14 2020 12:11 PM
Thanks for this; I really appreciate it. The no. 6716 is on a label on the back.
What about replacing the foam rings and cones?
Alex.
Dillen
Posts 13,191
Dillen replied on Sat, Nov 14 2020 12:52 PM
Bronowski:
Unless burned or physically damaged the drivers are usually fine, and no foam surrounds are used if I remember correctly.
Bronowski
Posts 15
Bronowski replied on Sun, Nov 15 2020 2:14 PM
Gently cleaned the speaker cones and a fair amount of dirt came off. Sound is definitely sharper. What I did notice is that the right speaker sounds ok but the left speaker has a hum coming from it. Can't hear much if anything from the left tweeter. Could this be due to the capacitor unit needing replaced on the crossover filter which you suggested should be replaced? The speakers are still in good condition and useable but need 'a nudge'.
Alex.
Page 1 of 1 (16 items) | RSS
