Hi everyone, I finally got my hands on a very nice Beosound 5 encore!
I have my music stored on Synology DS418play NAS. It runs a PLEX server which makes sure all the music is tagged and had proper albumcovers. I enabled the DLNA feature in plex, selected that as my N.Music server in BS5e, and.... nothing.
I thought the library was too big, so I created a PLEX server on my macbook with just 4 albums in it and no movies. Also that one did not show any music on the BS5e.
Then I installed the trial version of Twonky Server, with the same albums and it showed up and played immediately. But the meta tagging is not properly done, because Plex used to take care of that for me.
I saw this thread: https://archivedforum2.beoworld.org/forums/t/9629.aspx, and I also have seen the option of writing a user profile for the DLNA server of plex: https://archivedforum2.beoworld.org/forums/t/9629.aspx. That is a outside my comfort zone so before I dive into that, has anyone tried to make this work? I saw one person raising this issue too, but without a solution: https://forums.plex.tv/t/writing-profile-for-b-o-encore-5/66395
Thanks in advance. If I manage to get it working I will share my experience.
Beosound 5 Encore + Beosystem 5500 + S45.2; BV7-40 MKV + BL7.1 + BL14.4+ AppleTV4; various link rooms with MCL2 A or MCL2 A/V + RL60.2 / CX100 / CX50 & Cona / IWS2000; BG4000; Beosystem 1200 + BV1600.
Thank you your quick reply! I actually noticed that when I user plex dlna server as source for other dlna clients it actually gives all the album information and covers, which are missing when using Twonky or other dlna servers. That was also the reason to go that route.
Meanwhile I got two steps further: I was able to create a user profile, as described in my link above, for Beosound 5 encore that is recognized by PLEX. Still no content visible in my library, but it is a first step. To be able to listen to mu music I installed the linux version of Twonky on my synology DS418play, via ssh because it is officially not supported as package. So now I have music from the NAS, even m4a files coming from iTunes. But very few covers so I am not giving up yet.
Carolpa:Formal spoken: in origin Plex is no DLNA server.
Not sure I understand what it means? PLEX Media Server has a DLNA on/off configuration setting, has several DLNA configuration option, either through the UI of through configuration files, and I'm using this DLNA server on a daily basis, driving it with the B&O App against any of my B&O DLNA capable products.
The only not working thing is the ability for the BS Moment to harvest it. I have not spent much time on this issue as I would have no support from B&O for the BS Moment which would make the communication with PLEX support more difficult.
