BeoSound 9000 is Locked
Wilmadekrom
Posts 1
Wilmadekrom Posted: Sat, Nov 14 2020 7:16 PM
Hallo,
Ik ben de troste eigenaar van een beosound 9000. Een geweldig apparaat, maar, de glazen deur gaat niet meer open, ik krijg de melding "lock". Wat kan ik daar aan doen? Iemand een idee?
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
Locking of glass lid
The glass lid can be locked so that it cannot be operated.
Press: SHIFT 9 0 3 6 9.    The remote control terminal must be in audio mode.
The display reads: LOCK.
The function is stopped by pressing: SHIFT 9 0 3 6 9.    The remote control terminal must be in audio mode.
SHIFT is found under LIST on Beo4
The display reads: UNLOCK.
Regards Keith....
Keith Saunders
Posts 5,495
You said:-
But there is no shift option under List on beo 9000
there is only: edit, clock, reset, return, v. tape2 or a. aux
My Answer:-
The "LIST" contains the controls you have previously added.
To add additional controls to your LIST such as SHIFT do the following:-
  • Press the STANDBY and LIST button on your Beo4 remote at the same time you will then see ADD? press GO
  • Press the LIST button until you see SHIFT then press GO
  • SHIFT has now been added to your LIST
Regards Keith....
Page 1 of 1 (3 items) | RSS
