Hallo,
Ik ben de troste eigenaar van een beosound 9000. Een geweldig apparaat, maar, de glazen deur gaat niet meer open, ik krijg de melding "lock". Wat kan ik daar aan doen? Iemand een idee?
Locking of glass lidThe glass lid can be locked so that it cannot be operated.
Press: SHIFT 9 0 3 6 9. The remote control terminal must be in audio mode.
The display reads: LOCK.The function is stopped by pressing: SHIFT 9 0 3 6 9. The remote control terminal must be in audio mode.
SHIFT is found under LIST on Beo4The display reads: UNLOCK.
Regards Keith....
You said:-
But there is no shift option under List on beo 9000there is only: edit, clock, reset, return, v. tape2 or a. aux
My Answer:-
The "LIST" contains the controls you have previously added.
To add additional controls to your LIST such as SHIFT do the following:-
