CD 6500 not reading tracks on all CD
TomasKarlsson
Posts 2
TomasKarlsson Posted: Wed, Nov 18 2020 10:22 AM
Strange problem.
I bought a Beogram CD 6500 recently (1900 SEK) and it worked for two days.
Now it will only read tracks and play on one of my CDs. On the rest I have tried (around 10) it just "thinks" shortly and then shows a read dot at the right of the front panel. The remote shows "no source".
It is so strange - as soon as the one working are back in the tray, it just finds tracks and plays them normally.
What can I do to get it work?
Thanks in advance
Tomas, Mariestad, Sweden.
TomasKarlsson
Posts 2
Anyone with experience of this? Beogram CD 6500 perfectly reading one or two CD.s but cant find tracks on all other CD's?
I will try change the capacitors according to adwise at another place, but it sounds odd that the two same CD are always working perfectly, but not 20+ others I have tried with. What can it be if not the capacitors?
Tomas
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Dec 2 2020 8:36 PM
TomasKarlsson:
Tomas
Before thinking about everything that can be wrong, start by changing C2103(search the forum/web) capacitor, and cleaning the lens with isopropyl alcohol and a cotton swap.make sure to wipe after with a dry swap.
this will solve your problems 99% of the time.
/Weebyx
Page 1 of 1 (3 items) | RSS
