Beosystem 3 - HDMI ARC or / and Optical?
This post has 4 Replies | 0 Followers
dwrights
Posts 12
dwrights Posted: Fri, Nov 27 2020 6:20 PM
Hello Gents,
Quick question. I have searched but got conflicting views.
Besystem 3 Mk1 connecting to LG CX. I have already purchased the HDMI lead and the adaptor from Steve but do I also need to buy an optical cable so I can hear audio from the TV apps such as Netlix?
Kind Regards,
David.
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Fri, Nov 27 2020 6:28 PM
I've used a Marmitek 4K extracter with E-Arc and Audio out over hdmi. So, you're not limited to DD/DTS 5.1. Hdmi has uncompressed audio formats.
Doesn't work flawless as I have to switch manually on the Marmitek to E-Arc. But after switching on, it works well.
Named 1 input on the BS3 "TV" and used the hdmi socket at that AV to send the audio over. I use 2 PUC's in the BS3. The first one to switch on the LG, the other to control the LG panel throught the (4K) apps. No problems with lip-sync.
dwrights
Posts 12
dwrights replied on Fri, Nov 27 2020 10:00 PM
Hello again Beobuddy :-)
Like this one?
https://www.keene.co.uk/marmitek-hdmi-4k-audio-extractor-with-arc.html
Beobuddy
Posts 3,972
Beobuddy replied on Sat, Nov 28 2020 12:45 PM
This is the one I have:
https://www.keene.co.uk/marmitek-hdmi-connect-ae24-4k60-audio-extractor-with-arc.html
The ARC led switches off every time I put the LG to standby.
dwrights
Posts 12
dwrights replied on Mon, Nov 30 2020 9:12 AM
Just purchased one.
Many thanks for your help, most welcome.
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
