Hello,
I encounter a strange problem: my Beosound 5 ENCORE cannot connect anymore to the network because it has suddenly a bad configuration.
In "Settings" "Advanced" I can see the DHCP is disabled. Ok, I place it on "enabled", enter Go, then "Store" and the response is "Failed!". I don't know why.
All the fields IP address, subnet mask... are empty. I know the correct values to place it but I don't know how to enter and store it in the BS5.
As I'm living 3 hours driving from the next B&O store in normal weather conditions and seeing the snow falling, I don't think it would be a good idea to drive my car so long for that!
I've also phoned to the retailer, no help, B&O on Facebook inconclusive. So, I have to manage it myself.
I have no problems with computers and networks but I'm not a B&O technician.
Of course, I've tried to unplug the BS5, changed the RJ45 cable, reboot the router, reboot the BS5... anything I can imagine (logic or not).
Not yet a shaman or a sorcerer!
May someone help me?
Thanks a lot!
Best regards,
François
Just try a recovery. In most cases that will help. Not logical, but effective.
Beobuddy: Just try a recovery. In most cases that will help. Not logical, but effective.
Beobuddy what do you call 'recovery"? I have reboot or restore factory settings. I didn't see your recovery procedure.
Thanks for a little help more!
Beobuddy what do you call exactly a recovery? Thanks
Notwithstanding the factory restore, you could go into the service menu and set the network settings there, open a command window (CMD in the run... menu item on the main windows menu) and try to ping www.google.com. If that works, then the rest should do - if it doesn’t, the repair the network connection. If no luck there, then factory restore (assuming your network is actually connected!)
I’ve had several occasions where changing settings inside menu’s didn’t work. Customers or servicemenu. Didn’t work. So, the recovery option was finally solving the network issue. Assuming that cables, router settings are checked. Recovery can be chosen at the start when the BS5 is powered, or via service menu. Music will be saved.
Beobuddy frog
is the recovery what I see as factory settings restore?
I did it and maybe the problems came from there, my BS5 didn't light on itself after that, I'll did it myself pressing the Go button. I suspect the process didn't achieve correctly.
How do you go in the service menu? I don't have this in the BS5 Encore.
Connect a laptop with Windows XP? through a crossover cable?
I can do that and then?
I've found how to enter a fixed IP address, mask, gateway, DNS but, as the DHCP, it doens't want to store it and says briefly "connecting" and then "Failed!".
This is THE problem: I have no connection because the DHCP is off and I can't store the IP parameters.
Thanks for your help, I hope we could find an issue soon!
To get to service menu, you need to connect a mouse and keyboard to your BS5 (or sometimes just a mouse, depending on what you need to do). Then, you select "service menu" from the BS5 (go to "settings", then press >>, <<, >>, <<, GO, then select "Maintenance", then select "service men"). After you select "service menu" from the BS5 menu, the BS5 display becomes a computer monitor which shows the Windows XP screen which you can then control through mouse and keyboard. I use a wireless keyboard/mouse combo that I normally use with my laptop so I just plug the keyboard's bluetooth dongle into one of the USB ports, go to the service menu, and then you're in windows.
Hope this helps,
Stan
Stan this procedure doesn't applies to the Beosound 5 Encore which is not running Windows XP but Linux.
There is no need of a keyboard, the service menu has two choices: reboot or restore the factory parameters, you can access it with the arrows.
I did both. Nothing changed!
Has anybody an other idea?
For example connecting a laptop wth Windows XP and then... ? I have one. A crossover cable too if necessary.
Maybe some tools are mandatory for checking the lan card if there is one and to force the DHCP to be enabled back.
Thanks for your help.
You're mixing things up.
Stan is right on how to enter the servicemenu from the BS5 (with the BM5 as black box).
The Beosound Encore isn't a Beosound 5. So, about which product are we actually arguing?
You might try first some kind of netanalyzer or enter your isp modem/router, to see which ip-adres the BS encore.BS5 has been given.
Beobuddy I've always talked abaut Beosound 5 Encore, that's the product I own.
I've searched it on my network before you suggest me to do it and din't find it.
Of course, that's THE problem: DHCP has been desactvated, I don't know why, it's impossible to reactivate it with the BS5 Encore tools and impossible too to enter a valid IP address.
And no IP address + no DHCP = no network connection, nothing to see in the net analyser.
Nothing was changed in my router and all other equipments are OK. You can read me? So, it works.
Now I think there is two solutions:
- trying to solve the problem connecting a laptop with tools.
- throw the Beosound 5 Encore to the bin.
I prefer the first one.
Francois00: Hello, I encounter a strange problem: my Beosound 5....
There the cause of the confusion.
I assume that you've checked your networkcable, I don't have any experience with the BS Encore.
Francois00:- throw the Beosound 5 Encore to the bin.
Did you try WIFI?
Beobuddy Sorry, I've written Encore sometimes only.
Yesterday, I've checked with 4 different cables. Same thing. And if you think about it, it could be a problem but not in this case: I have no DHCP AND no fix address. Impossible to change those parameters.
I know only one way to force it to rebuild the entire listings of the music: restoring the factory settings. This option exists but always have been in grey.
I did it several times after having changed too many things in the USB HDD attached, always fine.
I suspect this time this operation had encountered a problem because I had network connection just before.
I think the B&O tools allows to boot on USB and flash a new system image in BS5 or BM5.
I'm pretty sure that would be the solution to my problem.
But I don't have it.
Carolpa as mentioned, I have no more DHCP default option (blocked on disabled) and no fix IP address.
So the WiFi connection can't operate.
I think my system has been corrupted as I described in my last post and the solution is to replace it with a new image via USB which is running well.
Francois00:I think the B&O tools allows to boot on USB and flash a new system image in BS5 or BM5.
Francois00:I'm pretty sure that would be the solution to my problem.
I would factory reset the BS5e.
Sorry, I did it ... several times.
As I've written up there, I suspect it has caused my problem with a bad termination for any reason.
I had network and N.Radio BEFORE to do it.
Not now. The RJ45 port is unusable, I have to find a solution with the USB port which works fine.
Another long shot, can you retrieve the MAC address from the BS5e? Then assign the MAC address to a specific ip-address in your router?
Francois00:Sorry, I did it ... several times.
Beobuddy yes, of course. And I did it too. But nothing, it's a simple network problem: no address in the BS5 Encore, no network. If you want to receive a letter, the postman has to know your address, it's the same thing.
As all other things are running well, I think the OS of the BS5 Encore to have a problem, probably caused by the first attempt to return to factory settings which didn't achieve correctly.
As far as I know, flashing a complete new OS would be the solution.
We have to forgot the network for reparing it, Only the USB port may be used now.
Carolpa yes both, several times. And it's probably the cause of the problem as I decsribed it.
Francois00:Carolpa yes both, several times. And it's probably the cause of the problem as I decsribed it. Thanks for your help. Best regards, François
Francois00:It really was a software problem and I've found the solution.
As I've founded the solution by myself without any valuable help and considering the price of the B&O products, it's not my job to repair the problems for free.
So, I'm thinking to sell this efficient solution if anyone is interested.
Merry Christmas,
Francois00:Hello, As I've founded the solution by myself without any valuable help and considering the price of the B&O products, it's not my job to repair the problems for free. So, I'm thinking to sell this efficient solution if anyone is interested. Merry Christmas, François
You want information for free, but don’t want to share a found solution. Only if I pay?? That is quite a contradiction on this forum.
An impersonation of Scrooge by saying: "Merry Christmas".?
+1 from me.
But I didn't receive any valuable informations.
I've foud the cause of the problem and the solution only by myself.
I'm sure B&O people are reading this forum.
They sell their products and the reparations ... So,me too.
My B&O retailer told me this was caused by the lan card which was broken! Sure!
Francois00:But I didn't receive any valuable informations. I've foud the cause of the problem and the solution only by myself. I'm sure B&O people are reading this forum. They sell their products and the reparations ... So,me too. My B&O retailer told me this was caused by the lan card which was broken! Sure! Merry Christmas, François
But I will not share information with you again, ....... your luck.
To my opinion members with this kind of attitude should be banned.
Merry Christmas to you also
Francois00: But I didn't receive any valuable informations. I've foud the cause of the problem and the solution only by myself. I'm sure B&O people are reading this forum. They sell their products and the reparations ... So,me too. My B&O retailer told me this was caused by the lan card which was broken! Sure! Merry Christmas, François
No, but your intention was to receive that kind of information....for free, when you first posted.
People on this forum - even those who more or less work for B&O - share their solutions for free (or they choose not to share).
Some of these solutions come from long and persistent testing and from what you usually call hard-earned, longlife experience.
That is the reason why Carolpa reacts as he does.....I fully agree with him.
Millemissen:That is the reason why Carolpa reacts as he does.....I fully agree with him.
I heard from the first sales he has ordered his first Ferrari
Hi Francois, did you need the Service tool to reload the firmware ? I must say that It does kind of go against the spirit of the Forum to want to charge. If you have a reasonable amount in mind I would pay a small fee. I have an Beosound 5 Encore with the same issue. If this doesnt solve the issue, do I then get my money back ?
Beolab 4000, Beolab 6000, Beolab 8000, Beolab 7-4 / Beocenter 1, Beovision 9/ Beosound 1 CD, Beosound 3, Beosound 5 Encore, Beolit 12/ Beocom 2
Maybe you have a USB HDD attached with too many songs? That's the initial cause of my problem.
I think the maximum has to be between 40 000 and 50 000 songs.
If you approach the limit, the system is freezing, you have to delete some albums from the HDD and try to rebuild indexes.
Often, the solution is to reset factory settings but, sometimes, it fails with a strange result, for example, no more network.
Even if the network, cable... everything is OK.
There is no need to pay anything, it was kind of a joke because I didn't get any help (including B&O retailer!), I was able to give networks lessons to the other saying ... did you test... yes, it's done, it works!!!
So, my solution is not really what you can call that but the result of strange manipulations and the hazard.
As often.
So, here it goes:
- you need a cordless USB keyboard. The one of your PC if you have.
- put your BS5 in service menu, go to "settings", then press >>, <<, >>, <<, GO, then select "Maintenance"
- insert the dongle of your USB keyboard in the USB port of your BS5 Encore
- select REBOOT and Go.
That's all folks!
Normally it runs fine.
I really don't know why, don't ask me, it's not logic for me or if I have an explanation, it's not clear at all.
The idea is that the system failed and to force it to reboot correctly, you have to change something in the hardware configuration.
Maybe you can try a USB mouse if you don't have a keyboard, it probably runs with anyhing else than a HDD plugged in this port while rebooting.
And, double check your HDD with Windows. If you have errors, it may cause problems.
Empty the bin also.
Try all that and tell me if it is succesful.
Bon courage.
Francois00:it was kind of a joke
Francois00:- you need a cordless USB keyboard.
what is the problem?
Carolpa:Francois00:it was kind of a jokeFrancois00:- you need a cordless USB keyboard.
