Beogram 5500 7 Pin Adapter?
davidst98
Posts 3
davidst98 Posted: Mon, Dec 14 2020 7:32 PM
The Beogram 5500 has a 7 pin din.
The only repair guy I can find here in the NoCal Bay Area only has 5 pin din stuff to be
able to test.  Do I need to buy a 7pin din female to 5 pin din male adapter?
Thanks for any help you can give me.
David
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, Dec 14 2020 8:45 PM
Pins 1 and 7 should unscrew. Use either a very small screwdriver or do it gently with needle nosed pliers.
sonavor
Texas, United States
Posts 3,732
sonavor replied on Mon, Dec 14 2020 8:48 PM
Guy:
Pins 1 and 7 should unscrew. Use either a very small screwdriver or so it gently with needle nosed pliers.
But take care not to lose them. You can't buy replacement removable pins for them.
-sonavor
Page 1 of 1 (3 items) | RSS
DigiCert Secured Site Seal
