Beolab 17 eol - will there be an alternative for a 5.1 config?
Ruud
NETHERLANDS
Posts 65
Ruud Posted: Mon, Dec 21 2020 11:30 AM
So the BL17 appears to be eol. A pitty. Will B&O launch a new speaker for these in short time which can be used in a 5.1 configuration?
Otherwise what is your advice to use in a 5.1 config with my bv eclipse with current bl6000 and bl11?
Beofan with current setup Beovison Eclipse 55, Beosound 35, Beolab 6000, Beolab 11, Beoplay A9 Mk4, Beoplay E6
Mikipidia
Posts 2,169
Mikipidia replied on Mon, Dec 21 2020 12:51 PM
Well you can still get them for now. Although they are eol, but i you did they would be front speakers for your scenario and you could ditch the bl11 and the bl17’s outperform those on their own.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Ruud
NETHERLANDS
Posts 65
Ruud replied on Mon, Dec 21 2020 1:32 PM
Mikipidia:
Hi Mikidia
Currently I have the Bl6000 as front and no rear. My idea was to use the bl17 as rear because the can be wireless connected. Is that smart ?
Mikipidia
Posts 2,169
Mikipidia replied on Mon, Dec 21 2020 2:07 PM
Well, it works obviously and it’ll be an improvement, but you’d be putting your best speakers at the back where they do the least. It’s up to you, but i personally would put the 6000’s in the back if you have 17’s.
kawo
Posts 148
kawo replied on Mon, Dec 21 2020 3:25 PM
There are not so many choices these day if you want new speakers. The BL17 are great speakers and if you can justify the looks I would put them in the front with no doubt.
If you go used, BL3 are one of the best surround speakers in terms of size, placement options and price. Even they will outperform the BL6000.
I have a pair BL3 in the back and BL4 as hights. Which brings you to an other option, BL4 as ceiling speaker as there is a cailing mount available as well. As speakers on floor level they are the least attractive and performing speakers from my point of view of all BL active speakers.
An underrated option is to go with two Beolab 7.4, they are quite powerfull and on the level of the BL3 and they are quite cheap (in the 100 Euro ball park and sometimes they come with a Beovision 7-32 free of charge..), may be the best bang for the buck.
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
