Beofan with current setup Beovison Eclipse 55, Beosound 35, Beolab 6000, Beolab 11, Beoplay A9 Mk4, Beoplay E6
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Mikipidia:Well you can still get them for now. Although they are eol, but i you did they would be front speakers for your scenario and you could ditch the bl11 and the bl17’s outperform those on their own.
There are not so many choices these day if you want new speakers. The BL17 are great speakers and if you can justify the looks I would put them in the front with no doubt.
If you go used, BL3 are one of the best surround speakers in terms of size, placement options and price. Even they will outperform the BL6000.
I have a pair BL3 in the back and BL4 as hights. Which brings you to an other option, BL4 as ceiling speaker as there is a cailing mount available as well. As speakers on floor level they are the least attractive and performing speakers from my point of view of all BL active speakers.
An underrated option is to go with two Beolab 7.4, they are quite powerfull and on the level of the BL3 and they are quite cheap (in the 100 Euro ball park and sometimes they come with a Beovision 7-32 free of charge..), may be the best bang for the buck.
