Hello and good day.I just bought my first B&O products, Pair of Beolab 17 and beolab 19 sub.
I also bought Transmitter 1 to connect the speakers wireless
I have I question regardin the setup.
In the setup guide I am faced with this question.
> Repeat step A to store the next loudspeaker to the same sound channel.
Or ...
> ... continue to step B to store the next loudspeaker to a new sound channel.
Should I put each speaker on new sound channel ?
or put them all on same ?
BW
Binni
During the speaker connection process, LEFT sound channel is configured first (Step A) follow by the RIGHT sound channel (step B).
You would repeat step A if you wanted to add more than one speaker to the LEFT channel, which is not the case as you only have a pair of BL 17, one for the LEFT sound channel, and one for the RIGHT sound channel.
Ok, And the Sub ?
Do I the sub to either channel ?
I doesn't matter, but specified in your documentation step 9, while configuring for stereo, the SUB is the latest speaker addition which usually occupies the Left channel of the second PL port.
