Hi
Anybody no the settings in my ml/nl convertor that will let the eclipse see the beomaster 5 to work speakers connected to eclipse.I also can not see any CD setting on my beo one but remote net flicks type
stuart50_1:Hi Anybody no the settings in my ml/nl convertor that will let the eclipse see the beomaster 5 to work speakers connected to eclipse.I also can not see any CD setting on my beo one but remote net flicks type
Before continuing 2,5 questions:
1. you only have a Beomaster 5 and not the Beosound 5?
2. what do you mean with "not see any CD setting". You have a BM5/BS5 with an addition CD player connected?
l have a Beosound 5 . What I actual mean is original when it was set up it had a Beovision 14 , and a Beomaster 5 in the same room speakers attached to tv .
And the Engener set the remote up and said link /Cd .
I can not find this on my new remote
And the Engener that fitted the eclipse had know idea about the nl/ml/convertor
I am afraid that Carolpa is right (bad service from your seller....or you did not ask specific).
No fully integration possible there - however, you can connect the sources (when set up correctly in the converter) to the Sound Center (of the Eclipse) and add these to the other Sound Center sources. This will have to be done in the Bang & Olufsen app.
BLC setup: assumption, N.Music is set as N.Music in the BS5; N.Radio is set as N.Radio in the BS5
In Configuration-Settings of the BLC
ML enabled=true ML role= VMaster; Save
Networklink: choose friendly name; Save; "connect to" both same <friendly name>; Save
Sources Visible on ML: set all "NL product name" to Empty; Save
In Experience mapped to NL: click the checkboxes (=true) of N.Radio and N.Music; Save
In IR mapping: N.Radio - NL productname=<friendly name>; Save
In IR mapping: N.Music - NL productname=<friendly name>; Save
option: reboot the BLC (unplug mains, wait a minute, replug mains), wait until the BLC is up and running.
Now do a test: start playing a track or album on the BS5 manually. Search for and choose the JOIN command on your BR1. The Eclipse should play the track/album.
Thanks will try that will bt1 control Beosound 5
stuart50_1:will bt1 control Beosound 5
Noting working yet
I think I have set everything correct have a look please
Hi I have tried to upload images of the convertor but i have not had much look
I have had some look with the beomaster 5.
I turned on the bombaster 5 had it playing then turned on the Eclipes and had a connection , the screen said CD with the circular link sign under it .
When I turn off the bombaster 5 with a long hold it does turn of all my B&O products so something is handing.
I am not sure how to access the CD ? n Music set up on the romete ?(how to move into the list on the some menu)
I could properly reset the Bombaster 5 as I do have access to the services screen ?
If it is posable I would like to use a CD sign on the remote BT1 to work the bombaster 5 ( if i can get it on theBT1 screen )
I did have this set up on the Beovision 14 with a BT1 remote so not sure why i can not repeat this agin
is it because Eclipse does not support CD on the BT1 ?
Press Save to store ALL displayed settings.
Assuming the above cannot be sorted (I had a BLC, but it was taken out by a lightening strike so I "replaced" it with an Essence since I wasn't really using the integration it provided for much more than what an Essence could do), I just use my BS5/BM5 as a DLNA music source for the Eclipse. You can't synchronize the playback from the BS5 and Eclipse, but you can at least play the music saved on the BS5. Even this is a little fiddly since the LG side of the TV also has a music app that will see the BM5. However, only through the sound center music setting will you be able to play WMA music (assuming you have "transcoding" enabled in the BS5). The LG music app only supports MP3 (and maybe Flac.)
Stan
double post
stuart50_1: turned on the bombaster 5 had it playing then turned on the Eclipes and had a connection , the screen said CD with the circular link sign under it .
stuart50_1:I am not sure how to access the CD ?
stuart50_1:If it is posable I would like to use a CD sign on the remote BT1 to work the bombaster 5 ( if i can get it on theBT1 screen )
Set the BR1 to control the BS5:
press List, then up or down until Settings; choose settings with OK; choose Advanced with OK; then Products; Show; up or down to Beo4 Audio, select with OK (it is checked).
Back, back, back... until black screen!
Now the BR1 can operate as a Beo4. How does it work? All command are NOW going to the Eclipse and NOT to the BS5. First you have to switch the BR1 to send the commands to the BS5. This is done by pressing List, then Up, then Right, then choose Beo4 Audio. If you have chosen the Beo4 Audio, all the commands go to the BS5. So if you press Music and go UP or Down repeatily you will find the CD. Select this by OK and the BS5 should start .
To access the Eclipse again: List, UP, Right, choose Beovision (or Eclipse, or... note: I do not know how your BR1 is programmed). If the BS5 is still playing press List, up/down until you see JOIN, choose JOIN. The Eclipse should join the BS5
Stuart, I did send a message to your post. But is was blocked to be moderated. Why? That's unclear to me.
SOLVED, see above!
Hi just got your post thanks
will try and let you know
Hi thanks for your help , I was trying to send pictures of the set up fields in my ml/nl convertor .And I made a mess of it I think that’s why I was blocked ?
I have done the set up on my remote and it does not start the Beomaster5 I think I am missing something
Music key know has CD in there , so we can not be fare away from making this work .
kind Regards Stuart
stuart50_1:does not start the Beomaster5 I think I am missing something
The BS5 is set to start music with the CD command? Normally it is set to react on N.Music (mayby try this also). Just to be sure: after selecting a source on the BR1, you confirm it with an OK?
HiBeosound5 is reacting to the bt1 remote turning volume up and moving to next track but I can not hear anything pressing CD ? Anymore ideas? Please.
stuart50_1:Hi Beosound5 is reacting to the bt1 remote turning volume up and moving to next track but I can not hear anything pressing CD ? Anymore ideas? Please.
thanks for all your help with this ,it’s a shame Bang Olufsen are not more help full.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
