Eclipse
This post has 21 Replies | 0 Followers
stuart50_1
Posts 65
stuart50_1 Posted: Sun, Dec 27 2020 12:49 AM
Hi
Anybody no the settings in my ml/nl convertor that will let the eclipse see the beomaster 5 to work speakers connected to eclipse.I also can not see any CD setting on my beo one but remote net flicks  type
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Dec 27 2020 5:49 AM
stuart50_1:
Hi
The Eclipse doesn't supports the fully intergrated option. Anything you will do will be a compromise.
Before continuing 2,5 questions:
1. you only have a Beomaster 5 and not the Beosound 5?
2. what do you mean with "not see any CD setting". You have a BM5/BS5 with an addition CD player connected?
stuart50_1
Posts 65
Hi
l have a Beosound 5 . What I actual mean is original when it was set up it had a Beovision 14 , and a Beomaster 5 in the same room speakers attached to tv .
And the Engener set the remote up and said link /Cd .
I can not find this on my new remote
And the Engener that fitted the eclipse had know idea about the nl/ml/convertor
Millemissen
Flensborg, Denmark
Posts 14,680
I am afraid that Carolpa is right (bad service from your seller....or you did not ask specific).
No fully integration possible there - however, you can connect the sources (when set up correctly in the converter) to the Sound Center (of the Eclipse) and add these to the other Sound Center sources. This will have to be done in the Bang & Olufsen app.
Fansastic
The Hague, The Netherlands
Posts 768
Fansastic replied on Sun, Dec 27 2020 9:58 AM
You can use the MyButtons for storing a source. The Netflix/Prime remotes only have 1 but you can also use a remote with 4 mybuttons. This will give you 4 sources you can store and use easily on the Eclipse.
First play the source (through NL/ML converter) and press join on the Eclipse remote. After the source is playing you can select different sound and stand settings and long press the MyButton. It will preset this source.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Dec 27 2020 1:15 PM
BLC setup: assumption, N.Music is set as N.Music in the BS5; N.Radio is set as N.Radio in the BS5
In Configuration-Settings of the BLC
ML enabled=true ML role= VMaster; Save
Networklink: choose friendly name; Save; "connect to" both same <friendly name>; Save
Sources Visible on ML: set all "NL product name" to Empty; Save
In Experience mapped to NL: click the checkboxes (=true) of  N.Radio and N.Music; Save
In IR mapping: N.Radio - NL productname=<friendly name>; Save
In IR mapping: N.Music - NL productname=<friendly name>; Save
option: reboot the BLC (unplug mains, wait a minute, replug mains), wait until the BLC is up and running.
Now do a test: start playing a track or album on the BS5 manually. Search for and choose the JOIN command on your BR1. The Eclipse should play the track/album.
stuart50_1
Posts 65
Thanks will try that will bt1 control Beosound 5
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Dec 27 2020 2:46 PM
stuart50_1:
BR1 will, with this settings, not control the BS5. But first let's have the BS5 up and running again.
stuart50_1
Posts 65
Hi
Noting working yet
I think I have set everything correct have a look  please
stuart50_1
Posts 65
stuart50_1 replied on Mon, Dec 28 2020 12:45 PM
Hi I have tried to upload images of the convertor but i have not had much look
I have had some look with the beomaster 5.
I turned  on the bombaster 5 had it playing then turned on the Eclipes and had a connection , the screen said CD with the circular link sign under it .
When I turn off the bombaster 5 with a long hold it does turn of all my B&O products so something is handing.
I am not sure how to access the CD ? n Music set up on the romete ?(how to move into the list on the some menu)
I could properly reset the Bombaster 5 as I do have access to the services screen ?
If it is posable I would like to use a CD sign on the remote BT1 to work the bombaster 5 ( if i can get it on theBT1 screen )
I did have this set up on the Beovision 14 with a BT1 remote so not sure why i can not repeat this agin
is it because Eclipse does not support CD on the BT1 ?
stuart50_1
Posts 65
Sources visible on ML
ML sourceNL product nameNL source
TV
EmptyBeoSound5LoungeBeoVision11-46
Empty
DTV
Empty
DTV2
Empty
V.MEM
Empty
DVD
Empty
DVD2
Empty
CAMERA
Empty
V.AUX2
Empty
PC
Empty
RADIO
Live TVNetflixMusicAmazon Prime VideoYouTubePhoto &amp; VideoApple TVDisney+ITV HubBBC iPlayerArt GallerySports AlertWeb BrowserAmazon AlexaHDMI 1apple tvHDMI 4Sky QHDMI BHDMI CHDMI DTuneInLine-InOpticalQPlayBluetoothMusic
A.MEM
CD
A.AUX
N.RADIO
N.MUSIC
 Disabled due to ML role
Press Save to store ALL displayed settings.
Stan
Chicago-area USA
Posts 869
Stan replied on Mon, Dec 28 2020 4:06 PM
Assuming the above cannot be sorted (I had a BLC, but it was taken out by a lightening strike so I "replaced" it with an Essence since I wasn't really using the integration it provided for much more than what an Essence could do), I just use my BS5/BM5 as a DLNA music source for the Eclipse.  You can't synchronize the playback from the BS5 and Eclipse, but you can at least play the music saved on the BS5.  Even this is a little fiddly since the LG side of the TV also has a music app that will see the BM5.  However, only through the sound center music setting will you be able to play WMA music (assuming you have "transcoding" enabled in the BS5).  The LG music app only supports MP3 (and maybe Flac.)
Stan
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Dec 28 2020 6:16 PM
double post
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Dec 28 2020 6:17 PM
stuart50_1:
This is correct! so the BS5 music played on the Eclipse. right?
stuart50_1:
This means your BS5 is set to start N.Music (the saved music files on the BS5 HDD) when you press the CD button (on a previous remote). Correct?
stuart50_1:
I did wrote before, the Eclipse does not supports a complete intergration. So you will have to compromise.
Set the BR1 to control the BS5:
press List, then up or down until Settings; choose settings with OK; choose Advanced with OK; then Products; Show; up or down to Beo4 Audio, select with OK (it is checked).
Back, back, back... until black screen!
Now the BR1 can operate as a Beo4. How does it work? All command are NOW going to the Eclipse and NOT to the BS5. First you have to switch the BR1 to send the commands to the BS5. This is done by pressing List, then Up, then Right, then choose Beo4 Audio. If you have chosen the Beo4 Audio, all the commands go to the BS5. So if you press Music and go UP or Down repeatily you will find the CD. Select this by OK and the BS5 should start .
To access the Eclipse again: List, UP, Right, choose Beovision (or Eclipse, or... note: I do not know how your BR1 is programmed). If the BS5 is still playing press List, up/down until you see JOIN, choose JOIN. The Eclipse should join the BS5
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Dec 28 2020 6:27 PM
Stuart, I did send a message to your post. But is was blocked to be moderated. Why? That's unclear to me.
SOLVED, see above!
stuart50_1
Posts 65
Hi just got your post thanks
will try and let you know
stuart50_1
Posts 65
Hi thanks for your help , I was trying to send pictures of the set up fields in my ml/nl convertor .And I made a mess of it I think that’s why I was blocked ?
I have done the set up on my remote and it does not start the Beomaster5 I think I am missing something
Music key know has CD in there , so we can not be fare away from making this work .
kind Regards Stuart
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Dec 29 2020 4:30 AM
stuart50_1:
The BS5 is set as: AM = On, Option set to 2?
The BS5 is set to start music with the CD command? Normally it is set to react on N.Music (mayby try this also). Just to be sure: after selecting a source on the BR1, you confirm it with an OK?
stuart50_1
Posts 65
Hi
Beosound5 is reacting to the bt1 remote turning volume up and moving to next track but I can not hear anything pressing CD ? Anymore ideas? Please.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Dec 29 2020 5:58 PM
stuart50_1:
Hi Beosound5 is reacting to the bt1 remote turning volume up and moving to next track but I can not hear anything pressing CD ? Anymore ideas? Please.
that is what I expected
The compromise is you have to start the BS5 and Join the Eclipse
Both the BLC and the Eclipse are connected to the same network
stuart50_1
Posts 65
Hi
thanks for all your help with this ,it’s a shame Bang Olufsen are not more help full.
Michael
Sweden
Posts 2,578
Michael replied on Wed, Dec 30 2020 6:02 PM
I would sell the beomaster 5 and go over to a modern solution. It was cool when it was new but is ancient today and actually even a threat to keep on your network as it runs windows xp and no firewall.
If left open like that at least. Cool device but soo old now. And not maintained. Sadly but true.
Page 1 of 1 (22 items) | RSS
