Beovision 10-46, how to select HDMI as input ?
jesperb
Posts 80
Silver Member
jesperb Posted: Sun, Dec 27 2020 12:06 PM
A friend has a Beovision 10 and we're trying to get it work with a new Chromecast, but no luck.
Rather, we cannot find out where to select HDMI as input.
Any help in this appreciated -we expect the Beovision should 'auto select' HDMI when a signal is negotiated?
The Beovision is a 10-46 Type 9555.
Release : Mar 2012
Ver : 0.1.8.9.2
Model : 1.0.0.0
Beogram TX, Beovox S45, Beovox MC 120.2, BeoSound 1, CX50, Beovox S75, Beomaster 2400, Beomaster 5000, Beogram 5005
beojeff
USA
Posts 2,012
beojeff replied on Sun, Dec 27 2020 12:44 PM
In the BeoVisions's setup menu you must assign to the correct HDMI input (A,B,C, or D) a source to use on the remote -- such as DTV, DVD, V.MEM, etc. Then, you can select the correct HDMI input by pressing the assigned source on your remote.
Millemissen
Flensborg, Denmark
Posts 14,680
@jesperb
There is no ‘autoselect’ on a Beovision (10) for the simple reason that idealy every connected device is controlled through the Beovision/the Beo4 via PUC.
This is the philosophy behind the ‘only one remote needed’ approach of B&O.
Devices like the Chromecast did not excist at the time when the BV10 was made.....any other external device had/has a remote, that we are very happy to put in the cupboard, when we have a Beovision ;-)
(B&O never used CEC in the Beovisions - since the PUC-controlling was much more reliable....at least back then).
Just follow the instructions from the post that beojeff wrote - and that you also can read in the manual.
jesperb
Posts 80
Silver Member
jesperb replied on Sun, Dec 27 2020 1:44 PM
Thanks beojeff & Millemissen,
Reading the manual was - of course - at LOT smarter, than messing about in the Beoworld forums ;-)
https://bangolufsenassistentgohe.blob.core.windows.net/manuals/TELEVISIONS/BEOVISION_10/beovision10_userguide_danish.pdf
Merry Christmas and thanks again.
Page 1 of 1 (4 items) | RSS
