A friend has a Beovision 10 and we're trying to get it work with a new Chromecast, but no luck.Rather, we cannot find out where to select HDMI as input.
Any help in this appreciated -we expect the Beovision should 'auto select' HDMI when a signal is negotiated?
The Beovision is a 10-46 Type 9555.
Release : Mar 2012
Ver : 0.1.8.9.2
Model : 1.0.0.0
Beogram TX, Beovox S45, Beovox MC 120.2, BeoSound 1, CX50, Beovox S75, Beomaster 2400, Beomaster 5000, Beogram 5005
In the BeoVisions's setup menu you must assign to the correct HDMI input (A,B,C, or D) a source to use on the remote -- such as DTV, DVD, V.MEM, etc. Then, you can select the correct HDMI input by pressing the assigned source on your remote.
@jesperb
There is no ‘autoselect’ on a Beovision (10) for the simple reason that idealy every connected device is controlled through the Beovision/the Beo4 via PUC.
This is the philosophy behind the ‘only one remote needed’ approach of B&O.
Devices like the Chromecast did not excist at the time when the BV10 was made.....any other external device had/has a remote, that we are very happy to put in the cupboard, when we have a Beovision ;-)
(B&O never used CEC in the Beovisions - since the PUC-controlling was much more reliable....at least back then).
Just follow the instructions from the post that beojeff wrote - and that you also can read in the manual.
Thanks beojeff & Millemissen,
Reading the manual was - of course - at LOT smarter, than messing about in the Beoworld forums ;-)
https://bangolufsenassistentgohe.blob.core.windows.net/manuals/TELEVISIONS/BEOVISION_10/beovision10_userguide_danish.pdf
Merry Christmas and thanks again.
