Hi
Happy new year all
set up my beolab 2 in speaker roles called sub. When I go out of the setting to watch tv sub turns it’s self of any ideas please .
stuart50_1:Hi Happy new year all set up my beolab 2 in speaker roles called sub. When I go out of the setting to watch tv sub turns it’s self of any ideas please .
My set up is eclipse , beolab 2 beolab 20 front and beolab 9 back , I can her all speakers in speaker roles , distance and level .
But when switched to tv the beolab 2 goes off
stuart50_1:Hi My set up is eclipse , beolab 2 beolab 20 front and beolab 9 back , I can her all speakers in speaker roles , distance and level . But when switched to tv the beolab 2 goes off
You should easily be able to hear what happens, when toggling bas management on/off.
See the instructions in the guide, that you have linked to under the section:
Setup: Sound: Sound Modes: PRESETNAME: Bass Management
Personally I’d remove (and maybe sell) the BL2, if I had the 20’s as fronts.
However - if you want to keep it - you could experiment a bit with the placement of the BL2 (move it to the back of the room) in order to control the bas better/avoid room modes.
For this you’d of course have to toggle bas management off.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Mikipidia:Like i said in your other thread: Go to the speaker preset menu where you can set the roles of your speakers and set the bl2 to on as subwoofer. It’s mostlikely not switched on in the preset you’re using(start up)
Note: the Energy Save Settings can also switch speakers of.
