Speaker settings
This post has 8 Replies | 0 Followers
stuart50_1
Posts 65
stuart50_1 Posted: Fri, Jan 1 2021 1:15 PM
Hi
Happy new year all
set up my beolab 2 in speaker roles called sub. When I go out of the setting to watch tv sub turns it’s self of any ideas please .
lawrencejmcook
Posts 742
stuart50_1:
Hi
Happy new year all
What main / front speakers are you using, and what are the speakers connected to?
If you’re using a Beosystem 3 or 4, or equivalent BeoVision, and your main speakers are BeoLab 5 or better, the Beosystem / BeoVision will switch the bass sound from the BeoLab 2 to the bigger, more capable speakers, leaving the BL2 mute.
stuart50_1
Posts 65
Hi
My set up is eclipse , beolab 2 beolab 20 front and beolab 9 back , I can her all speakers in speaker roles , distance and level .
But when switched to tv the beolab 2 goes off
lawrencejmcook
Posts 742
stuart50_1:
Hi
Hi Stuart,
The BL20s are definitely more capable of delivering low bass than the BL2, and the Eclipse sound center almost certainly recognises that. The feature is called Bass Management. It sends low bass to the speaker(s) most capable of delivering it, even if this means removing all sound from a sub.
The technical sound guide for your television should mention this somewhere. It used to include a matrix showing which loudspeakers would cause the BL2 or BL11 to be muted. If I can find it, I’ll paste a link.
Lawrence
lawrencejmcook
Posts 742
Hi Stuart,
Here is the link to the current technical sound guide for the Eclipse:
https://bangolufsenassistentgohe.blob.core.windows.net/manuals/TELEVISIONS/TECHNICAL_SOUND_GUIDE/technical_sound_guide_televisions_2004.pdf
Whilst it no longer includes the matrix, it describes Bass Management in section 3.3.6.
Lawrence
lawrencejmcook
Posts 742
Hi Stuart,
According to the matrix in the TSG version from Sep2014, bass management will NOT remove bass from a BL2 and add it to BL20s or BL9s:
https://bangolufsenassistentgohe.blob.core.windows.net/manuals/TELEVISIONS/BEOVISION_HORIZON/Technical-Sound-Guide-1409.pdf
Now, this matrix was removed from later versions of the TSG, so I can’t be sure of the current logic, but it’s possible that your BL2 should work.
If the BL2 plays a test tone when you’re setting the speaker levels, then maybe you just need to add it to the speaker groups that you use.
Lawrence
Millemissen
Flensborg, Denmark
Posts 14,680
You should easily be able to hear what happens, when toggling bas management on/off.
See the instructions in the guide, that you have linked to under the section:
Setup: Sound: Sound Modes: PRESETNAME: Bass Management
Personally I’d remove (and maybe sell) the BL2, if I had the 20’s as fronts.
However - if you want to keep it - you could experiment a bit with the placement of the BL2 (move it to the back of the room) in order to control the bas better/avoid room modes.
For this you’d of course have to toggle bas management off.
Mikipidia
Posts 2,169
Mikipidia replied on Sat, Jan 2 2021 12:48 AM
Like i said in your other thread:
Go to the speaker preset menu where you can set the roles of your speakers and set the bl2 to on as subwoofer. It’s mostlikely not switched on in the preset you’re using(start up)
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Jan 2 2021 10:45 AM
Mikipidia:
Like i said in your other thread: Go to the speaker preset menu where you can set the roles of your speakers and set the bl2 to on as subwoofer. It’s mostlikely not switched on in the preset you’re using(start up)
Or/and the bass is set to be redirected to other spearkers connected to the Eclipse.
Note: the Energy Save Settings can also switch speakers of.
Page 1 of 1 (9 items) | RSS
