Beo1, the ancient remote.
This post has 10 Replies | 1 Follower
tamtapir
Örebro, Sweden
Posts 521
tamtapir Posted: Mon, Jan 4 2021 11:24 AM
Is the Beocenter1 remote control useful for anything other than Beocenter1?
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, Jan 4 2021 11:35 AM
I wouldn't say useful, but there is a sequence of key presses that sets up a Beo1 to control other TVs as follows:
Press Standby+Display+Stop at the same time
Press Stop and hold the button whilst pressing double arrow right, then release both
Then press Display once
I had to try this a few times before getting it to work, but even then the functionality is very limited!
tamtapir
Örebro, Sweden
Posts 521
tamtapir replied on Mon, Jan 4 2021 11:53 AM
Guy:
Thank you! That is, anyway  all?
Useless but goodlooking little bugger.
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, Jan 4 2021 12:01 PM
tamtapir:
Yes, I used to display one in my little museum!
matador43
Posts 1,373
I used to have an interest in that remote to control Beocenter 6 basic functions: Volume, Source, Stand.
because it is better looking that a beo4 (even if the beo4 is better looking than…)
A member from Beoworld lend me one. My conclusion was it is quite useless.
I replaced it with a well programmed Beo6 with unresponsive screen but that do a perfect job at what is needed.
Stoobietoo
Exeter, Devon, UK
Posts 692
I did see a thread in the forum years ago where someone took one apart and inserted a ATV remote (white one) into the case to control their ATV/Mac Mini.
The buttons all lined up inside and it worked.
Stoobie
matador43
Posts 1,373
Stoobietoo:
Stoobie
So great!
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, Jan 5 2021 9:15 PM
Stoobietoo:
Here, but sadly the photos are missing: https://archivedarchivedforum2.beoworld.org/forums/p/34291/282837.aspx#282837
Stoobietoo
Exeter, Devon, UK
Posts 692
What a pity the pictures are missing. I did consider getting a Beo1 to convert but never got round to it .
I eventually got a Beo5 and Beo6. I now also have a Lintronic, and getting to grips with that. You can change what you can control with the Beo1 using the Lintronic including non B&O. But as there are so few buttons you are still restricted to how many functions.
Stoobie
OldJack
Split
Posts 371
OldJack replied on Wed, Jan 6 2021 1:28 AM
Best looking remote ever. For some reasons,it attracts ladies attentions.. I am still using it with my (still good working) Beovision1,ended up wall mounted in a garage.
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
CB
> You are Here <
Posts 1,762
CB replied on Sun, Jan 17 2021 6:32 PM
Stoobietoo:
User Soundproof may still be on the forum —> ask him
Page 1 of 1 (11 items) | RSS
