Hi there, my Beocenter 9500 and another Beocenter 9000 are not saving the settings anymore after turning it off or in stand by. Is there a battery which is responsible to save the settings ? If yes where is it placed and can it be replaced ?
It's probably the battery, which for the BC9500 is here (red circle marks the spot!):
EDIT: And yes you can replace it but it is a little tricky to get to. I replaced with one of these: https://uk.farnell.com/renata/cr2450-nfh-lf/cell-lithium-button-2pin-3v/dp/1319731?CMP=i-bf9f-00001000
ah there it is. Tank you so much for your help !
I thought that sound settings have to be saved through beolink 1000....
