Beocenter 9500 not saving SOUND settings
This post has 3 Replies | 0 Followers
Andreas
Vienna
Posts 72
Andreas Posted: Tue, Jan 5 2021 6:43 PM
Hi there, my Beocenter 9500 and another Beocenter 9000 are not saving the settings anymore after turning it off or in stand by. Is there a battery which is responsible to save the settings ? If yes where is it placed and can it be replaced ?
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, Jan 5 2021 8:25 PM
It's probably the battery, which for the BC9500 is here (red circle marks the spot!):
EDIT:  And yes you can replace it but it is a little tricky to get to.  I replaced with one of these: https://uk.farnell.com/renata/cr2450-nfh-lf/cell-lithium-button-2pin-3v/dp/1319731?CMP=i-bf9f-00001000
Andreas
Vienna
Posts 72
Andreas replied on Tue, Jan 5 2021 10:01 PM
ah there it is. Tank you so much for your help !
Sventchik
Posts 43
Sventchik replied on Tue, Jan 5 2021 11:26 PM
I thought that sound settings have to be saved through beolink 1000....
Page 1 of 1 (4 items) | RSS
