Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
I got a reply from my dealer that they have experienced other customers with similar problem.
Could be a problem with an amplifier module.
I will contact their service technician.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Mikipidia:Was going to ask first if you were sure it hadn’t come loose in any way, but glad they seem to have an idea of how to fix it New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0 Mikipedia on YouTube: https://www.youtube.com/c/Mikipedia mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4 Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Problem solved. It was one of the preamps that had problems. After a quick service visit the BV11 is back in its old glory again Cost 3500 SEK = approx 345 Euro including travel and servicecost.
Serviceman: [extracts Kay Bojesen Monkey from the connections wiring trough, places it on the table] "Ahh, there's your rattling noise!" [Exeunt omnes.]
trackbeo:Serviceman: [extracts Kay Bojesen Monkey from the connections wiring trough, places it on the table] "Ahh, there's your rattling noise!" [Exeunt omnes.]
